Tip & How-To about Televison & Video
Vestel washington flashes and goes to stby again
Replace some capacitors
c106,c108,c117,c122 and c124 100uf.
they are located on the board near the powersupply
Televison & Video Logo
refrigerator clicking
There are 4 capacitors that need to be replaced to solve this issue with WKKT Model No: 0158-06-03 These caps are listed below. C106 470uf 25v recommended (470uf 35v) C29 470uf 25v " " C6 10uf 25v C100 47uf 25v
Feb 02, 2013 | GE Refrigerators
Have a blown capacitor in a QSC PLX 3602. It's the large black capacitor near the on/off switch. Can't read the letters and numbers. What is this capacitor? Thank you.
I need a board marking number as there may be several caps near the on/off switch.
Example:
C117 .47mfd 250VAC (use 600VDC)
C126 .1mfd 250VAC (use 600VDC)
C132,133,136,137,140,141, All 2200mfd 200VDC (These are large canned units)
Note if one of the latter ones, better check the full wave rectifier bridge for a bad diode as well.
I have the schematic but not an assembly drawing so description of near switch doesn't tell me enough.
Oct 29, 2010 | QSC PLX3602
Magnavox 19MF337B/27 LCD TV problems
The bad capacitors in this set are usually NOT on the power supply--they are on the other (logic) board. You will find several bulging capacitors there. Replace em all....
Nov 06, 2009 | Televison & Video
Philips model HD2528-C122 value for capacitor C506?
I could still make out 68 over 2kv on the burnt capacitor. Replaced with a 680 pf 2kv that I bought at a local TV repair shop. works great.
May 27, 2008 | Televison & Video
175 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
