Tip & How-To about Refrigerators
How to be safe your refrigerator safe for many years?
Keep it joined with voltage controller or stabliser.it should be placed at that place in the room where the pass out of gas is much,so it can exchange more heat from inside to outside.
Refrigerators Logo
How do heat exchangers work?
The heat exchanger is a thin metallic component of a fossil-fueled furnace whose purpose is to transfer heat from the gas or oil buning on one side of the sealed chamber to the air passing across and coming in contact with the other side of the sealed chamber. By 'sealed' I mean the burning gasses do not come in contact with the air that circulates within the living space.
Mar 11, 2015 | Heating & Cooling
With in 3 1/2 years two time main board went bad, inlet valve went bad, whether I keep that machine or I exchange that machine. machine problem or product problem ?
I believe that you have problem with fluctuatin of voltage in Line. Will be a Good idea to install a Stabilizer Voltage in line for to control of Heater , and to keep safe the control board.All the machine will be expose to this fluctuation.
God bless you
Oct 15, 2013 | Whirlpool 6th Sense 40-Gallon 6-Year Tall...
i want to sign in to yahoo messenger and join to chat room?
sign in your Yahoo Messenger. Then go to MESSENGER, then YAHOO! CHAT, then JOIN ROOM
MESSENGER is located at the upper portion beside the CONTACTS. i hope this helps. goodluck!
Apr 12, 2011 | Yahoo Messenger
My potterton boiler ignites itself after turning it on then goes out
Assuming this is a combi boiler and you mean that the main gas burner comes on then off:-
How long after - 5-20 secs check overheat thermostat Check the wires to it are firmly in place i.e. making a connection. If Ok? then you can short this out by joining the wires together - do with boiler OFF at mains electricity
Longer - say 1-2 mins check secondary heat exchanger for blockage - usually furred up inside & only solution is replacement
Dec 22, 2009 | Water Heaters
147 people viewed this tip
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
