Tip & How-To about Vacuums
How to Replace The Cord Reel in a Miele Canister Vacuum Cleaner
Ok, so you need to replace the cord reel on a Miele Canister Vacuum, no problem! I'll attempt to try and walk you through this repair with a detailed explanation of it, and along with some pictures to help you. You'll first want to buy a new Miele series cord reel for your particular model.
Here are links to all of the Miele cord reels if you haven't already purchased one.
Miele Cord Reels & Rewinds for All Brands
So once you have the cord reel, you'll need either a Phillips head screw driver for the older Miele models, or a T20 Torx Screwdriver for the newer models. The picture below is actually of the Miele S518 Cat & Dog series, but for this repair the procedure is identical to most Miele canisters . You'll need to remove the hose, wand, and power nozzle from the vacuum cleaner before you begin.
The first thing you'll wand to do is open up the bag housing, and remove the vacuum bag, as well as the exhaust filter which may be either the Cloth Super Air Clean Filter, or the HEPA Filter cartridge which is blue in color. If you're using the Super Air Clean filter, remove the filter, and then remove the bracket that secures the filter in place as well. Simply pull straight up on the bracket and it will come out.
Once the bag and the filter have been removed, you'll need to take off the entire tool lid. While the vacuum cleaner is open so that you can see into the compartment where the bag just was, you need to pry two arms from the tool lid off of the main body housing. Simply put a screwdriver behind one of the blue arms, and pry inwards. Here's a picture of what this looks like;
Once you have removed both of these clasps, the tool lid will pull straight upwards and off, leaving you with only the bottom part of the canister. This is how the vacuum cleaner should look now;
Now you'll need to remove the black speed control box from the canister. There is one screw in the front of the black speed control box that needs to be removed. After the screw has been removed, turn the vacuum cleaner around so that the back of the machine where the cord reel goes into the vacuum is now facing you. If you look where the black speed control box meets the bottom part of the canister, you can see two clips that you'll need to release before the variable speed control box can be removed. Simply put a screw driver and push in on the clip while lifting the black speed control box at the same time. Here's where the clips are located on the vacuum;
Ok, now that the speed control box has been removed, it's time to separate the colored plastic from the base of the vacuum cleaner. There are 7 screws that need to be removed in order to get these housings separated. I have circled the location of each screw in the picture below;
After removing all 7 screws, you can then simply pull upwards on the colored plastic housing, and remove the housing from the base of the vacuum cleaner so that the motor and cord reel are exposed. Once you have exposed the cord reel, you'll need to remove the internal wires (white wire is in the higher position, and to the left of the lower right side black wire), as well as the rubber hose part. The rubber hose part simply pulls off, just like the wire terminals do. After removing these parts, you'll need to remove one more screw with your screw driver. Here's the picture of which screw needs to be removed;
After the final screw has been removed, you'll have to remove the rectangular shaped wire harness that sits at the top of the cord reel. Pay close attention to how this wire harness is correctly seated which will save some aggravation when putting the vacuum back together. Here's a picture of the wire harness that needs to be removed from the old cord reel;
Once the wire harness has been completely removed from the old cord reel, you may simply pull up on the cord reel and remove it. The new cord reel will come completely assembled, with all the parts and components that your faulty cord reel had. You simply need to line up the screw hole on the new cord reel with the hole in the bottom of the base of the vacuum. When installing the new cord reel be very careful that you don't pinch any of the wires down by putting the cord reel on top of them. The wires have a specific place they go, and you'll be able to see the correct path for these wires when paying close attention. Also remember to install the rubber tube back onto the new cord reel as well. Once the new cord reel has been installed, and screwed down, pull the plug out a little ways, and guide the plug through the colored top housing first, then screw the 7 screws that hold the upper housing to the lower housing back into to secure these housings together.
That's about all there is to that repair! Please feel free to request a repair clarification if you have any questions about the repair that I can help you with, I'm always more then happy to help.
If this repair guide was helpful to you, please click the thumbs up icon in the bottom right part of this solution to rate it has helpful.
Thank you,
Chris J.
GoVacuum
Vacuums Logo
Power Cord
Hi There,
Greetings,
This definitely sound like a cord reel issue to me. This is really the only problem that I ever see on a Miele vacuum 9 times out of 10 the cord reel needs to be changed. If you purchase the cord from us, and it's not the problem you may return it up to 60 days later for a full refund, that's how confident I am that is what's wrong with your machine. Unfortunately when this begins to happen, it's extremely difficult to fix this problem on the cord reel. It may be better for a short period, but it will continue to get looser, and looser until it finally won't turn on at all. It's really best to just go ahead and replace it at this point.
Ok, so you need to replace the cord reel on a Miele S514 Solaris, no problem! I'll attempt to try and walk you through this repair with a detailed explanation of it, and along with some pictures to help you. You'll first want to buy the new Miele S500 series cord reel. If you haven't already purchased one, here's a direct link to the exact cord that's needed for your S514:
Miele Cord Reel For All s500 Series #05240304
So once you have the cord reel, you'll need either a Phillips head screw driver for the older S514 models, or a T20 Torx Screwdriver for the newer S514 model vacuums. The picture below is actually of the Miele S518 Cat & Dog series, but for this repair the procedure and parts are identical to the S514. You'll need to remove the hose, wand, and power nozzle from the vacuum cleaner before you begin.
If this repair guide was helpful to you, please be kind and leave feedback for the repair. This is what continues Fixya repair professionals to continue giving free repair service rather then just doing the premium pay for repair help. This is really appreciated.
Thank you so much,
Chris Jones
GoVacuum.com
Apr 17, 2010 | Miele Filtration Guard S528 Canister...
Miele just stopped working?
When a Miele canister just stops working all of a sudden, it's usually a pretty clear indication that either you have a bad cord reel, or a bad switch. I would say that in 60% of Miele repairs that I do with this problem, the cord reel has gone bad.
One easy thing that you can try to see if the cord is bad, is put one hand on the on/off switch, and the other hand grab the cord (making sure it's fully retracted inside the canister). Now pull the cord out slowly with your one hand, while continously turning the switch on / off, on / off. Keep pressing the switch on and off while pulling on the cord. Usually if the cord reel has gone bad, then you may hear the vacuum attempt to start, or even turn on while you're pulling on the cord. The cord reels in Miele use a metal spring inside that makes connection with the rest of the vacuum. Over time this spring will start to loose it's strength, and eventually will get so bad that it no longer makes contact with the rest of the vacuum. By pulling the cord out slowly and pressing the on / off switch, a lot of the times the spring will make connection somewhere, and the motor may turn on temporarily.
If this happens, this indicates your cord reel needs to be replaced. I have done a detailed repair here on Fixya on how to replace the cord on a Miele canister vacuum that you may read here;
http://www.fixya.com/support/t2281026-miele_s514_will_not_come
If you can't get the vacuum to turn on at all, this can only mean a few things. First the cord reels spring is gone completely, and wont make any connection with the rest of the vacuum, and you'll still need to replace it.
It also can mean that just the plug that plugs into the wall is bad, is your plug bent, or no longer straight on either prong?
It can also mean that your motor has gone bad. This however is usually the least likely of all the problems. The Miele motors are almost bullet proof, and typically last 20 years. I can count on one hand the number of Miele motor replacements I've ever done in 10 years of fixing vacuums.
I can try and help you diagnosis this further if my suggestions didn't help you. Please use the clarification request that you see here on this page to ask me a question. Please just let me know what happened when you tested the cord out as I suggested above. I really hope this was helpful to you. If you found this to be helpful, please be sure to rate the repair as helpful to you by clicking the thumbs up icon. I really appreciate that.
Chris J.
Mar 21, 2010 | Miele S318 Bagged Canister Vacuum
Miele Champagne Vacuum Cleaner Model S548 I was using the vacuum as normal, moved locations so I plugged into another outlet & suddenly there was no power to the vacuum! I tried it in several other outlets, tried the reset button... & still no power to the vacuum. Any ideas what could be causing this? Any info would be greatly appreciated. Thank you!
Greetings from ,
This definitely sound like a cord reel issue to me. This is really the only problem that I ever see on a Miele vacuum cleaner. 9 times out of 10 the cord reel needs to be changed. If you purchase the cord from us, and it's not the problem you may return it up to 60 days later for a full refund, that's how confident I am that is what's wrong with your machine.
Ok, so you need to replace the cord reel on a Miele , no problem! I'll attempt to try and walk you through this repair with a detailed explanation of it, and along with some pictures to help you. You'll first want to buy the new Miele S500 series cord reel
So once you have the cord reel, you'll need either a Phillips head screw driver for the older S514 models, or a T20 Torx Screwdriver for the newer S514 model vacuums. The picture below is actually of the Miele S518 Cat & Dog series, but for this repair the procedure and parts are identical to your Miele Champagne. You'll need to remove the hose, wand, and power nozzle from the vacuum cleaner before you begin.
The first thing you'll wand to do is open up the bag housing, and remove the vacuum bag, as well as the exhaust filter which may be either the Cloth Super Air Clean Filter, or the HEPA Filter catridge which is blue in color. If you're using the Super Air Clean filter, remove the filter, and then remove the bracket that secures the filter in place as well. Simply pull straight up on the bracket and it will come out.
After removing all 7 screws, you can then simply pull upwards on the colored plastic housing, and remove the housing from the base of the vacuum cleaner so that the motor and cord reel are exposed. Once you have exposed the cord reel, you'll need to remove the internal wires (white wire is in the higher posistion, and to the left of the lower right side black wire), as well as the rubber hose part. The rubber hose part simply pulls off, just like the wire terminals do. After removing these parts, you'll need to remove one more screw with your screw driver. Here's the picture of which screw needs to be removed;
Once the wire harness has been completely removed from the old cord reel, you may simply pull up on the cord reel and remove it. The new cord reel will come completely assembled, with all the parts and compontents that your faulty cord reel had. You simply need to line up the screw hole on the new cord reel with the hole in the bottom of the base of the vacuum. When installing the new cord reel be very careful that you don't pinch any of the wires down by putting the cord reel on top of them. The wires have a specific place they go, and you'll be able to see the correct path for these wires when paying close attention. Also remember to install the rubber tube back onto the new cord reel as well. Once the new cord reel has been installed, and screwed down, pull the plug out a little ways, and guide the plug through the colored top housing first, then screw the 7 screws that hold the upper housing to the lower housing back into to secure these housings together.
Thank you so much,
Chris Jones
Feb 09, 2010 | Miele Blue Moon Bagged Canister Vacuum
No power when plugged in
Greetings,
This definitely sound like a cord reel issue to me. This is really the only problem that I ever see on a Miele vacuum cleaner2_bing.gif. 9 times out of 10 the cord reel needs to be changed. If you purchase the cord from us, and it's not the problem you may return it up to 60 days later for a full refund, that's how confident I am that is what's wrong with your machine.
Chris Jones
GoVacuum.com
Jan 04, 2010 | Miele S514 Solaris Bagged Canister Vacuum
My Miele S544 Artico just quit working. I took it
Greetings from GoVacuum,
The repair for your model is identical, and no it doesn't cost $500, we sell cord reel for $103. I'll attempt to try and walk you through this repair with a detailed explanation of it, and along with some pictures to help you. You'll first want to buy the new Miele S500 series cord reel (hopefully from GoVacuum), You may purchase the S500 Series Cord Reel Here; Miele Cord Reel - s500 Series #5240304 .
So once you have the cord reel, you'll need either a Phillips head screw driver for the older S514 models, or a T20 Torx Screwdriver for the newer S514 model vacuums. The picture below is actually of the Miele S518 Cat & Dog series, but for this repair the procedure and parts are identical to the S514. You'll need to remove the hose, wand, and power nozzle from the vacuum cleaner2_bing.gif before you begin.
The first thing you'll wand to do is open up the bag housing, and remove the vacuum2_bing.gif bag, as well as the exhaust filter which may be either the Cloth Super Air Clean Filter, or the HEPA Filter catridge which is blue in color. If you're using the Super Air Clean filter, remove the filter, and then remove the bracket that secures the filter in place as well. Simply pull straight up on the bracket and it will come out.
If this repair guide was helpful to you, please click the four thumbs up icons in the top right part of this solution to rate it has helpful.
Thank you so much,
Chris Jones
GoVacuum.com
Jul 06, 2009 | Miele S544 Artico Bagged Canister Vacuum
183 people viewed this tip
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
