Tip & How-To about Plumbing
Well Cleaning and Water Well Quality
You have had a water quality test and found that you private well is contaminated with bacteria. The next question is what can you do for water well treatment to make the water well quality acceptable for you and you family.
This question and tip was brought to my mind after getting an email from a brother in law about how to treat his water well with chlorine to kill bacteria is his well. So here is the process that you can use to treat your well if you know or suspect that you may have bacteria in your well water. This can also be used for regular well cleaning also. The chlorine will release the dirt in your well and the water will bring it up when you run the water. Regular treatment with chlorine is very effective at keeping a well free of debris and algae.
Go to your grocery store and purchase gallon of regular strength unscented Clorox bleach. The generic bleaches will work just fine also as long as they are unscented. This will cost only a couple of bucks. Also, if you have a water filter, make sure that you grab a couple of extra filters. The dirt released will plug the filter quickly. A carbon filter is a good idea for removing the last bit of chlorine smell from the water after purging the well of the chlorine.
Take the well cap off of the top of your well. Use a six foot or so long piece of PVC pipe to pour the chlorine through. This will keep the chlorine from getting on the pitless adapter and ruining the brass parts. They do not like each other.
After dumping in the chlorine, run your water at every tap in the house both hot and cold till you get the smell of the chlorine. It is best if you do this when you will not be using your water for at least 10 -12 hours, like at bedtime. Then let it set as long as possible to give the chlorine time to disinfect the piping and water.
After this time, then run the water till you remove the chlorine from the well and the piping. For some wells this will not take long and for others it may take a very long time.
This process has now given you a clean well and a disinfected water system!
This also is a very good way to make sure that you have good clean water, after a water well pump replacement.
http://www.fixya.com/support/r3689163-water_problems_pump_problems
http://www.fixya.com/support/r3690698-pump_problems_water_tank
http://www.fixya.com/support/r3690937-pump_problems_pressure_switch
http://www.fixya.com/support/r3695577-jet_pump_jet_water_pump
Plumbing Logo
NEED TO KNOW HOW TO GET ICEMAKER OUT TO EMPTY IT
TURN OFF YOUR CAPS LOCK!!!!
Why on earth do you think the ice is "contaminated"?
The power outage would have to be days long to do something like that. The ice has to melt and the water has to become warm enough to grow bacteria or mold in a freezer full of frozen items.
If you just let it cycle through, it'll push out the "bad" ice cubes and you can just toss them out. The next ones will be made with fresh water.
Sep 07, 2016 | Refrigerators
does some bagged lettuce have bacteria in them?
Undoubtedly. There have been warnings about rewashing bagged vegetables. Vegetable soap is sold around the country.
Apr 21, 2016 | Cooking
What is aerobic water treatment?
Aerobic water treatment means that bacteria that are oxygen dependent are converting contaminations in the water. Aerobic bacteria can only convert compounds when plenty of oxygen is present, because they need it to perform any kind of chemical conversion.
Aug 23, 2012 | Brita Camping, Backpacking & Hiking
COULD AN OLD UNDER SINK WATER FILTER GIVE OFF A HORRIBLE SMELL?
Absolutely! This is a common problem when filters have not been changed at regular intervals, improper method of changing filters, contaminating the housings and filters introduces bacteria into the system and there is no better place for it to live and prosper. Any drinking water system needs regular sanitizing to prevent the buildup of bacteria. If the drain is not properly plumbed in with an air gap, cross contamination can occur from the the DWV line also.
This system is no longer safe to drink from. The good news is it can be sanitized and filters replaced to get you back in business. www.softenerparts.com sells a sanitizing solution for RO systems and the filters you need also.
RJ
Jan 07, 2011 | Culligan Under Sink Water Filter
600 people viewed this tip
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
