Tip & How-To about Computers & Internet
For a virus don't click on anything
If you get popup on your screen from some unknown program, telling you that it has found trojans on your system do not click on scan or close, Instead press these two ALT & the F4 keys at the same time to get rid of the pop-up
Computers & Internet Logo
trojan virus promblem after open *** webside
Follow the given instructions to remove Trojan Virus from your PC.
1. Launch an antivirus program that you should have installed on your computer, such as Symantec's Norton or McAfee. Wait for the program's window to appear, then go to "Disk View." Highlight your computer, then select "Scan/Repair" so that the antivirus can detect the Trojan and trash it.
2. Exit the antivirus program on your Mac. Restart your computer again to ensure that the Trojan has been deleted. Empty the trash can on your computer once it is back up and running.
3. Disable the System Restore feature if you're a Windows user. Go to "Start" at the bottom of your screen, then right-click the "My Computer" icon to go to "Properties." Check "Turn off System Restore" under the System Restore tab in the "Properties" window, then select "Apply." Confirm that you want to disable System Restore by clicking "Yes" and "OK."
4. Update your virus definitions in your antivirus program. Open the program, or go to the website, to download the latest definitions so that you can receive the most recent alerts and keep your computer protected.
5. Scan your files to detect the Trojan file. Follow the instructions in your antivirus program to delete any suspicious files. You may want to write down the path and file name of the Trojan, which is usually found in the "C:\" hard drive. Then, edit your computer's backup registry by choosing "Start," then "Run." Type "regedit" in the window that appears and click "OK."
6. Search for the registry entry from which the Trojan derived, which may begin with "HKEY" followed by the file path. Delete the registry entry to ensure that the Trojan is removed. Exit the registry entry, and restart your computer so that the changes can take effect.
Dec 24, 2010 | Webroot AntiVirus with AntiSpyware &...
how to remove trojan horse virus in usb 2gb
Connect USB drive to USB port.When icons appears in My Computer, right click on it. A popup menu appears showing option for virus scan.By clicking on it scan the entire drive.
But dont ever open that USB drive, if there is a possible trojan. because when you will open that USB drive, the trojan will be copied into your hard drive automatically.
Best way to remove trojan is to completely format your USB drive.
Oct 29, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Popup stated "I-Worm.Trojan.b" found on your computer.
Download Avast from download.com Avast is a very good free software that will set the record straight on whether you have a virus or not. When you download it, change all the settings to high so it scans archive files as well. And make sure you do a boot scan.
http://download.cnet.com/Avast-Home-Edition-Free/3000-2239_4-10019223.html?tag=contentBody;mostPopTwoColWrap
Jun 19, 2009 | Webroot AntiVirus with AntiSpyware &...
Buffer Overrun detected prog files\yahoo browsetr\y browser.exe
Hi
Download Malwarebytes, update it.Then disable your system restore.Boot up in safe mode.Do a full scan on your pc.What IE you using?I would upgade your IE as well.
May 07, 2009 | Computers & Internet
unknown trojan
do not download that spyware, use spybot.com for that, it is safe and easy to use... you can also goto cnet.com and use Adaware which is very good for spyware issues.. please let me know if you have more difficulty.. do you have some sort of security on your pc or router? i hope this helps clean up your pc, it works for me all the time.. i run both the programs just to see sometimes what one will find versus the other.. good luck.. d
Feb 22, 2008 | Computers & Internet
133 people viewed this tip
David Payne
David Payne
