Tip & How-To about Televison & Video
How to repair a vizio tv that turns off at random
1.) Unplug everything from the TV [power, hdmi, av, and more]
2.) Because the Vizio holds power while unplugged you can reset it while its unplugged.
3.) hold power button on the tv down for about 60 seconds.
4.) plug the power only back in.
5.) turn tv on
6.) if it works then plug each component in one by one
7.) enjoy your tv
8.) start saving for a non vizio tv.
Televison & Video Logo
RCA video works. HDMI 1-4 do not work. No video
first do the power reset procedure . unplug tv hold power button on TV down for a minute. then plug tv back in then turn on.. see if the HDMI works .. if not test the HDMI cables/devices on another tv.
Jun 14, 2014 | Vizio XVT553SV 55 in. LCD TV
My Vizio VU37L HDMI ports not working. AV ports work. Heavy lightning storm last night, TV was off when I went to bed, on when I woke up.
If you send the board to us we may be able to fix it.
What you're looking for is having to replace the small SMD IC that the tracks from the HDMI ports lead to.
Sometimes that is all it takes, other times it needs more and just today I've had a case where we just couldn't do anything as the damage seem to have spread to the large processor.
(it wasn't on a Vizio board, it was on a Sanyo, but the concept is the same)
www.coppelltvrepair.com
May 22, 2014 | Vizio GV42L 42 in. LCD Television
50" Vizio Plasma reads "No Signal" on all inputs?
Well, your TV is still under warranty. That's the good part.
The only thing I can recommend without voiding the warranty is leaving the TV unplugged for 30min. That way, the TV can reset itself and hopefully correct the problem.
If that doesn't solve the problem, it's time to use the VIZIO warranty.
Here's contact info if you need it.
Technical Support
Toll-Free: 877.698.4946
(877 MY V I Z I O)
Technical Assistance Emails:
techsupport@vizio.com
Customer Service
Toll-Free:888.849.4623
(888 VIZIO CE)
Jun 17, 2009 | Vizio VP50 10A 50 in. Plasma TV
Vizio L32 32 in. HDTV LCD HDMI input not working
I recently had the same problem with my vizeo hdmi port # 1 going bad. Tried everything to fix and called vizeo. There solution for a master reset was turn off tv and unplug from the wall. then hold down the power button for 30 secs and let go. plug the tv back in and hold down the volume down and input select buttons down on side of the tv for 15 secs. release the buttons and turn the tv on after powering down all the components connectd to the tv. If this does not work they told me you need to have it sericed for a bad hdmi input. Hope this info helps anyone out there. It didn't work for me. Its a bummer cause the tv is well taken care of and only 18 months old. Best of luck to all others.
May 14, 2008 | Vizio L32 32 in. LCD HDTV
LCD TV picture is green
I just called Vizio and they said to unplug the TV, then physically hold in the power button on the TV for 2 minutes.
Nov 19, 2007 | Vizio L37 Television
244 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
