Tip & How-To about Washing Machines
Difficult to open washing machine doors
Some makes of washing machine doors can be very tight to open resulting in the door handle taking the strain and premature failure....I find if you take a wet rag and rub both the door boot seal and washing machine glass where they both make contact this lessons the DRAG on the door, it will close easy and glide open making the resistance to the door handle kit lower increasing its life span...
Washing Machines Logo
AEG Lavamat 6250 - opening door?
Try spoon handle gently prise open
Nov 12, 2009 | Washing Machines
Suspect door handle is broken on Indesit Washer Dryer WD12x
yes u can open door from the inside,take the top off (take plug out first)put your arm down to near the door latch and you will feel the mechinism there just gently push down or up until the door opens,if water is still in the washer then take drain pipe out of the waste pipe and place a bucket on the floor then put the pipe in that to manualy drain it,hope this helps you,ps you can buy a new door handle from any washing repair shop and they are easy to replace just see how the old one comes off,rgrds,paul
Jul 07, 2009 | Indesit W 123 Front Load Washer
Broken door handle for a Thor washing machine
there r 2 ways to get the door open 1)use a normal knife and place in front of the door handle push it in and it should open 2)pull the plug out take the lid off now place your hand down to where the catch goes into the washer using your fingers u should be able to pop it open with a bit off fiddling
Dec 15, 2008 | Hotpoint Aquarius WD640 Front Load...
whirlpool duet washing machine dooe handles
as you say the door sticks ,
so the handle is not the issue ,
your latch is ,
either it is not lubed or out of line .or has some plastic damage inside it,
it should only take a few ounces of pull ,
use your pinkie and only a small strain and its open.
any more and you have your issue .
its the latch.
unless its rubbing around the other plastic panel parts nothing should touch.
Oct 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Fixing broken door lock of Indesit W123X washing Machine
no easy way to open
disconnect from mains
take top off. feel down the front to where the door lock is and see if you can feel the door peg sticking thro the door interlock. force this with your fingers and with luck the door will open
if can't do this way, break handle off and lever peg with a small screwdriver
you can buy a handle kit complete. fitting this is not difficult - split the door and all will be revealed advise you make a carefull note of where springs go etc before you start stripping it down or take a few fotos if you have a digicam
Jul 10, 2008 | Indesit W 123 Front Load Washer
149 people viewed this tip
Top Washing Machines Experts
