Tip & How-To about Computers & Internet
When Windows XP won't start (secondary fix)
Symptom: You've tried the primary fix (the easy one) and you aren't successful. You keep ending up on the menu screen and nothing works.
Solution: Once again, boot to a Windows installation CD. This time, though, you will need a CD that has the same version of Windows that you are running (for instance, XP Home, XP Pro). When you get to the first question asking if you would like to repair Windows or install it, choose the "install" option.
You will be asked to press the F8 key to accept the terms and conditions. Do that.
The next screen "should" ask you if you wish to repair an existing installation or install a new one. Choose the "repair" option and follow the prompts. It will probably ask you to choose the installation to repair, so do that. There should only be one instance of "Windows" to repair. Now you'll see it deleting files and installing new ones. The nice thing about this option is you won't be losing data. If all goes well, your computer will work just like before with all your programs and data intact.
One thing you will need, though, is the Windows Certificate of Authenticity--that is the five groups of 5 letters and numbers that should be stuck on the outside of your computer case.
If this doesn't work, you will probably have to do a full reinstalllation of Windows or repair the registry which I will cover in a later tip.
Computers & Internet Logo
PC not booting up.
if its windows after you push the power button keep pushing f8 till you see a boot menu / choose boot in safe mode then you can use system restore /sounds like a bad driver/ loose processor/bad fan improper cooling could be the graphics card itself
Aug 02, 2017 | ASUS P5N73-AM Motherboard
The picture on my TV is cutting off on the top & sides of the screen.
If model indicated is correct and picture is shrinking on all four sides it indicates a problem in the main power supply.
Usually in this case you may also see a ripple or wave move up or down in the picture.
If a Primary voltage drops it will cause this symptom.
Mar 16, 2012 | Televison & Video
When i switch on my acer aspire 5735 i see a blue screen informing me that windows is updating 3 of 3 updates but nothing happens as the screen just hangs for hours? Thanks
i think your windows was updating itself but there is a problem with the update maybe you did not finish the update or the update file got corrupted. try if you can go safe mode that might fix the problem if still the same you need to reinstall your Windows.
if you are familiar with Windows installation there is an option there wherein you can repair your previous Windows installation. try that it might help before reinstalling windows.
Apr 14, 2011 | Acer Aspire 5735 Notebook
Won't turn off and cylces through colors
Hi. This evening, I had the exactly the same symptom. I found a way to fix it.
When you power up the screen, keep the power and auto buttons both pressed. That seems to reset the screen. After that when you open the menu, a small F appears on the left side of the contrast icon. Go to that red F with the arrows and press menu. Another menu will popup. Choose 'Burnin' and set it to off. That's all !
Note: do not try to change other settings, they depends of the harware...
Apr 30, 2007 | Acer AL1715 17" LCD Monitor
nikon 5700 takes a blank picture
There was a line of defective Sony sensors that went into a lot of cameras between 2004 and 2005. As far as I know the 5700 was the primary victim in the Nikon line but Nikon is offering to repair or replace the affected cameras regardless of warranty status. http://www.nikonusa.com/email_images/nikonusa/service_advisory/coolpix.html Good luck
Apr 29, 2006 | Nikon Coolpix 5700 Digital Camera
482 people viewed this tip
David Payne
David Payne
