Tip & How-To about Office Equipment & Supplies
How to resolve Communication Failures with Dell printers
Those who use Dell printers are not unaware to Communication Failure issues with Dell printers. This article help you with just the same.
The problem could be because of ONE out of FIVE problems listed below. Try the steps recommended and it should fix the problem.
  • Cable Issue: It could be a possible issue with the cable. Try replacing the USB cable.
  • Drivers Issue: Try uninstalling the printer drivers using the utility http://ftp.us.dell.com/printer/R166248.zip. Be sure to disconnect the printer from the computer before proceeding with the un-installation. Then download the Printer drivers from the Dell support website. Use the link: http://support.dell.com/support/downloads/driverslist.aspx. Select your printer model or enter your printer Service Tag and save the drivers for your corresponding Operating System. Next, install them on your machine and follow the onscreen instructions while installation. Also, DO NOT forget to update your computer's chipset drivers before this. This ensures that the USB drivers for your motherboard are updated too. If you fail to update the chipset drivers, you may have to flash your system BIOS to the latest version available.
  • UAC issue: If you are using Windows Vista or Windows 7, a feature called User Access Control (UAC) would block the printer communication. Disable it, and it should work. Use the linkhttp://www.petri.co.il/disable_uac_in_windows_vista.htm for tips on how to disable UAC.
  • Print Spooler Service Error: Either the service is stopped or not started correctly. Try restarting the printer spooler services on your computer. For tips on how to restart the Print Spooler service, use the link: http://www.ehow.com/how_2319117_restart-print-spooler-xp.html
  • Firewall Issue: Maybe your firewall is blocking the connection to your printer. Try allowing access to all applications related to Dell or printer or communication systems under Program Permissions in your Firewall program.
Thanks,
Abhishek
I HAVE ERROR CODE 1102, WHAT CAN I DO? LEXMARK P4300 ALL IN ONE INKJET PRINTER
The error indicates a communication failure between one of the cartridges and the printer. Please follow the steps below to identify and fix the issue:
Please refer to this article on the Lexmark website to fix the issue about 1102 Error Message on the Lexmark P4300 Series All-In-One.
Oct 25, 2011 | Lexmark P4350 All-In-One InkJet Printer
My printer will not print. I can scan images but nothing happens when I go to print a document. There is no box that comes up that states there is a problem.
Your firewall could be blocking the print communication. The article below will guide you on how to allow full access to all Lexmark software and printer communication processes in the program rules/permissions for your firewall.
- Communication Failure When Trying to Scan, Print, or Perform a Smart Solution Function; Firewall Possibly Blocking a Process and Preventing Communication
Hope this helps.
Aug 24, 2011 | Lexmark X4650 InkJet Printer
can't connect to home wireless network
This could be a firewall issue. Make sure to allow full access to all Lexmark software and printer communication processes in the program rules/permissions for your firewall.
Place your printer where it receives excellent wireless signal quality and away from other electronic devices which can cause wireless interferences (e.g. cordless phones, microwave ovens, baby monitors, garage door openers, and other wireless electronics).
Here are some articles that will help fix the issue:
- Wireless & Network Communication Issues with 2008 Lexmark Inkjet Products
- How to identify a Wireless Communication Problem and Resolution Tips
Aug 14, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
what does it indicates when the wifi light is flashing red in the lexmax z2420
The flashing light indicates that the printer is either trying to connect to a wireless network, a "connection failure" or a communication is not available. This article should give you ways on how to fix wireless connection problems - How to identify a Wireless Communication Problem and Resolution Tips. Hope this helps. Thanks.
Jan 21, 2011 | Lexmark Z2420 Printer
483 people viewed this tip
jasbo
jasbo
