Tip & How-To about Zebra 110Xi III Plus Thermal Printer
How to locate and align the media sensors on Zebra Xi series and Z105 series printers
One of the most common problems with Zebra Xi, XiII, XiIII, Xi4, and 105S,105Se, 105SL series of printers is sensing or proper advancement of the labels. The printer has two sensors, top and bottom, that must be properly aligned with each other.
The label passes between the sensors. The idea is that the label blocks the light between the two sensors and the gap between each label does not block the light. So the labels advance based on light, no light, light, no light etc... When you press the calibrate button, the printer is checking for this alternating condition. The printer also uses this principle to know when there are no more labels. Once the condition stays at “light” for a certain distance, the printer will show “out of labels”.
Here’s what is important to understand: These two sensors can be moved left and right across the width of the printer. They move independently of each other and this is what usually causes problems with the labels not advancing properly. See my video at the link below and it will walk you through step-by-step on how to properly align the two sensors.
**Note that the red light you see in the “throat” of the printer when you raise the printhead is not the sensor being discussed here. That red light is a “reflective” or “mark” sensor and is used for labels that have no vertical gaps and have a black mark printed on the backside of the liner.
Video tip:
Zebra 110Xi III Plus Thermal Printer Logo
Zebra 105Se not working
www.clearprintsolutions.com
Oct 12, 2009 | Zebra 105Se Thermal Printer
Hi. I Recently inherited a Zebra 140 XiII(2) and I cannot set the print speed as the option doesn't show on the LCD menu or when I print out the printer config settings. Any help would be appreciated.
Print speeds on the Zebra xiII series printers are set via software. There is no printer menu speed setting on the xiII series. Zebra didn't allow speed adjusts thru the front panel menu until they made the xiIII series printers... The ZPL code command for print speed is "^PR"
Jul 16, 2009 | Zebra 140Xi II Thermal Printer
ZebraDesigner Pro is changing my settings
If you have two printers 105se and the 105sl must install the two printers and select the correct model when you print your labels.
Mar 10, 2009 | Zebra 105SL Thermal Label Printer
2,950 people viewed this tip
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
