Tip & How-To about Cell Phones
Phone Cannot Send or Receive Calls and Text Messages: A Simple Electronic Glitch
It is frustrating when only your phone cannot send text messages no matter how strong the network signal is. Sometimes you feel nobody cares about or remembers you because nobody calls or texts you but actually there are. Your phone just can't be reached or can't receive text messages. When these happen, turn off the phone; remove the battery and then the SIM card. Insert the SIM card to another phone and try sending text messages; if you still cannot send text messages, remove the SIM card and let it sit off the phone for at least fifteen minutes then insert it gain. You should be able to send text messages after that, but make sure you have credits.
The next thing you should look into is the phone. Make sure network signal is present then insert a known good SIM card in your phone and try sending text messages. Reset the phone if you still cannot send text messages, but back up important files and data, such as contacts, videos, images, and messages, before doing so.
One simple way to "reset" the phone is by removing the battery and letting it sit for at least fifteen minutes. Another way is by restoring the phone settings to factory settings. Simply navigate to settings then phone settings and select "restore to full factory settings" depending on the brand and model of the phone.
This tip is not intended to solve virus or firmware problems but rather to avoid unnecessary visit to the service center and save few bucks from a problem only caused by a simple electronic glitch. Check the network signal strength and your credits before jumping into any conclusion.
Cell Phones Logo
I can't send an MMS or pic on my straight talk ZTE Majesty cell phone
If you do not have at least 2 steady bars of reception strength, text messages or pic messages could fail sometimes. If these fail no matter what signal strength, you should contact your phone provider (StraightTalk).
Jun 13, 2014 | ZTE Score
how do i set up GPRS on a china I4 phone
Good day. Call your network provider, and talk to the online personnel for this matter. Ask assistant for configuration settings of your phone, they will automatically send you the configuration settings thru text message. Once you receive the settings save as default for your phone, then try to run the GPRS, sometimes it takes an hour to run for test, depending on your area if you have a strong signal. Thanks
Sep 11, 2011 | Cell Phones
unable to send or receive text messages. strange symbol in top left corner of screen....help!
Network provider sometimes caused this problem because of their system mulfunction or upgrade. With that sometimes we can call but texting unable to send or received, but sometimes a signal indicator is full but not connected to the network provider, it means a feak signal. My recomendation is to contact network provider hotline and tell your problem or replace simcard. If yuo totally cannot call and text then positive your fone has a signal problem and need repair on it. Good luck
Jan 11, 2011 | Nokia 6300 Cellular Phone
My phone can't write text messages (they are converted straight to MMS and when i convert it to text it still dosen't work), nobody can receive them, i can't reply to anything (it keeps expecting me to record a message to send when you press reply). Sony Erricsson W995
Problems sending or receiving SMS may be caused by no or incorrect SMS settings. To set up your phone to use SMS, you need a message centre number, which is provided by your network operator. This is often set up automatically when inserting a new SIM card to a phone. Whiteout the message centre number, you are not able to send or receive SMS.
To edit the service centre number:
  1. Select Menu > Settings > Connectivity >Message settings.
  2. Select Text message.
  3. Highlight Service centre and select Edit.
  4. Highlight a service centre number and selectOptions > Edit > Continue.
  5. Enter the service centre number and selectSave > Yes.
  6. Highlight the service centre number and selectSelect to use the defined service centre number.
To add a service centre number provided by your network operator:
  4. Select Add to add a new service centre number.
  5. Enter the service centre number and selectSave.
This should help you.
any further questions feel free to ask.
Thanks.
Nov 19, 2010 | Sony Lands Phones
Delay in sending Text Messages with the Nokia E62
Just turn your message memory to Sim instead of memory stick.. it would become very fast. I had the same problem its solved now
Jan 02, 2009 | Nokia E62 Smartphone
401 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
