Tip & How-To about Cameras
Nikon offers Free Repairs on the D70, D2H, F55
Nikon has posted the following notice on its Support page for the D70 / D2H / F55 cameras:
" It has come to our attention that electronic components related to exposure control in some D70 cameras may, on rare occasions, fail.
Should you experience this problem with your D70 camera, Nikon will replace the associated components free of charge even if the camera’s warranty has already expired. We sincerely apologize for any inconvenience you may have suffered because of this problem."
To check if your camera has failed due this reason, please read the symptom description as follows:
How can I identify if my camera is faulty?
With a memory card inserted: The green memory card access lamp blinks continuously and camera does not respond to any controls.
With no memory card inserted: The camera will not turn on despite the battery indicator showing a fully charged battery.
How can I contact Nikon on-line?
You must be registered for Nikon support. Make sure that all your personal details are registered in full and are up to date, as these will be used if you return your product to us. You must also register your D70 and serial number.
1. Register for Nikon Support.
If you are not registered for Nikon Support, create a new account. If you already have an account, check that your personal details are up to date and that you have registered your product and serial number. To do this, login and click the ‘My Account’ tab, then click the ‘Profile’ sub-button. When finished, click the ‘Save’ button at the bottom of the page.
2. Submit your Question
Click the ‘Ask a Question’ tab near the top of the page and fill in the required fields, please add the words ‘D70 notice’ to the ‘Title’ field and add your comments to the ‘Question’ field.
When you have finished, click the ‘Submit Question Button’ and then you will be asked to click the ‘Finish Submitting Question’ button on the last page.
We will endeavour to answer your question as soon as possible.
NIKON Support:
http://nikoneurope-en.custhelp.com/cgi-bin/nikoneurope_en.cfg/php/enduser/std_alp.php?p_sid=yHTDQxQh
Cameras Logo
slight pull to the left, notice more wear on left side of front tire than the right
Because it is a front tire, and a single tire at that, there is only two things that can cause that a bad faulty tire (inside wire spreading ) or break hanging up. Have first tire checked, but problem is once tire starts wearing on one side it will continue until, replaced. So to not have it happen again and ruen new tire have breaks front and back checked. Thanks mike
Jun 08, 2011 | 2004 Honda VTX 1300
I have a Nikon d70 SLR. I had this camera completely cleaned and tuned up 3 months ago. Recently I can not take pictures. The battery powers the camera, but the shutter wont engage. An "error" message appears on camera. It has not been dropped or damaged that I know of. Is there any reset button or any troubleshooting advice other than take it to Nikon.
Read the manual on how to do a two-button reset. Also: from the nNikon Support Page on the D70::
It has come to our attention that select electrical components in a limited number of D70 cameras may, in some instances, fail affecting camera performance and/or operability.
While only a limited number of D70 cameras are affected by this advisory, if (1) when a memory card is inserted, your D70's memory card access lamp blinks, locking camera operations and preventing operation, or (2) with no memory card inserted, the camera will not turn on despite the battery indicator showing a fully charged battery, Nikon Inc. will service it free of charge.
To obtain complimentary service for cameras affected by this advisory, please click the link below to download and print the Service Return Form. The Service Return Form provides return instructions.
The Frequently Asked Questions button at the bottom of this page offers more information about this advisory and, should you have more questions, also provides information about how to contact Nikon.
We apologize for any inconvenience you may experience.
Sep 03, 2010 | Nikon D70s Digital Camera
Hallo!I have nikon F-4 with all range AF lences .I would like to know which model from Digital series D I can buy to use my AF old range of lences?
The Nikon DSLR with the screw mount motor can be used. The older D50 and D70/D70S, D80, D90, D100, D200, D300/D300S and the pro series D1H, D1X, D2H/S, D2X/S and D3/S can use the AF lenses in A/P/S/M model.
Hope this helps,
Andrew
Oct 01, 2009 | Nikon Coolpix 8800 Digital Camera
Problem with Nikon D70
The error code "CHA" is telling you that the CF card you are using for storage is not compatible with the camera. You should consider trying a different card, perhaps a slightly older one that is not as fast.
I use a SanDisk Ultra II card, and that works fine for me.
Dec 10, 2007 | Nikon D70 Digital Camera with 18-70mm Lens
Stray line on viewfinder
These lines are normal. See the last paragraph on page 8 of the D70 manual.
Sep 19, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
107 people viewed this tip
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
