Tip & How-To about Computers & Internet
My computer is running slow
In order to optimize your computer performance, follow the instructions given below.
1. Delete all of the temporary files.
a. Click Start, Click Run(Window XP) and type temp(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required), Click Edit at the top in the menu bar, click Select All, Right Click on Mouse and hit Delete. This would delete all of the temporary files.Note:in Window Vista and Window 7, Menu bar would appear by hitting Alt key.
b. Click Start, Click Run(Window XP) and type %temp%(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required), Click Edit at the top in the menu bar, click Select All, Right Click on Mouse and hit Delete. This would delete all of the temporary files.
c.Click Start, Click Run(Window XP) and type prefetch(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner,once you click Start), hit Enter, (hit Continue if required), Click Edit at the top in the menu bar, click Select All, Right Click on Mouse and hit Delete. This would delete all of the temporary files.
2.Run Disk Cleanup to free up wasted space.Click Start, click My Computer, right click C drive and click Properties. Now, click Disk Cleanup. It will delete all of the useless temporary files.If it ask to click Next, click Next.
3. Run Disk check.Disk Check program is used to check and clean any errors on your computer and keep it running smoothly.
How to run Disk Check:Click Start, click My Computer.Right-click on C drive, click Properties.Now, click the tab, Tools. In the Error-Checking section, click the Check Now. Also, check both of the check boxes: Automatically fix file system error and scan for and attemp bad recovery of bad sectors.
Now, You will see a message box that says you can schedule the disk check to start the next time you restart your computer. Click Yes. The next time you restart your computer, it will automatically run through a disk check before displaying your login screen. After the disk check finishes, Windows will automatically bring you to your login screen.Note: Check Disk can take more than an hour to check and clean errors on your computer.
4.Defragment Your ComputerTo arrange the files in a sequential manner, it is recommended to defragment the hard drive. Click Start, click My Computer, right-click Local Disk, aclick Properties.Now, the Tools tab, click Defragment Now. Now, Click first hard disk, click Defragment.Note: Disk Defragment may take long time like 30-40 minute to complete.
5.Stop Programs from running at the startup.
As soon as you restart the computer a number of programs load themselves at the startup and you will be able to see them at the bottom right-hand side corner. In order to stop some of the programs (except security software and programs which you use immediately after starting up your computer) to load itself automatically, please follow these steps.
Click Start, Click Run(Window XP) and type msconfig(Window Vista and Window 7-type in the Start Search box which appears at the botton once you click Start),hit Enter, (hit Continue if required)You will see System Configuration Utility. Click Startup at the top right hand side corner. Now,uncheck the items which you want to stop to load automatically.Now, click Apply and then click OK or Close. Click 'Exit without restart'Now, you have to delete the startup from registry.Click Start, Click Run(Window XP) and type regedit(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required),.Now, scroll up to the top and click Computer, rigth-click it and click Export and save it as file name say backup on the desktop.
In order to remove startup from the registry go the following locations:
HKEY_LOCAL_MACHINESOFTWAREMicrosoftSharedToolsMSConfigstartupfolder
Right click startupfolder and click Delete.
HKEY_LOCAL_MACHINESOFTWAREMicrosoftShared ToolsMSConfigstartupreg
Right click startupreg and click Delete.
Restart your computer.
6.Uninstall the useless programs(like gaming softwares, unnecessary toolbars like my web search, myfreeze toolbar)Click Start, click Control Panel, Click Add or Remove programs(Programs and Features or Programs in Window Vista and Window 7),you will see a list of the programs. Click on the programs, you want to uninstall and click Remove(Uninstall in Window Vista and Window 7).
7.Scan the computer with good antimalware, antispyware, antivirus.
http://malwarebytes.org/http://superantispyware.com/
8.Update the drivers on the computer.Click Start, Click Run(Window XP) and type devmgmt.msc(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required).Right click the device, click Properties.Click Driver tab, and click Update Driver.Follow the on screen instructions to complete update.
9.Upgrade RAMWindows can run slow if you do not have enough RAM.Many newer operating systems and programs use more RAM when they are running.How to check RAM.Click Start, right click My Computer, click Properties. You will see the RAM mentioned her.You should have at least 1 Gb(2 GB would be even more better)RAM.
10.Update Windows
Windows XP:Click Start, click Control Panel,Click Performance and Maintenance, Click System, click Automatic Updates tabclick Turn automatic updating on and click install updates.
Windows Vista:Click Start, click Control Panel, click System and Maintenance,click Windows Update,click Turn automatic updating on and click install updates.
Computers & Internet Logo
computer turns on but will not load windows. Freezes after gateway comes on. Plus cannot start in safemode
Enter the BIOS and ensure that the Hard drive is indeed being seen by the computer.
Open up the chassis side panel and ensure that all conections are making contact.
damnor01
Apr 14, 2011 | Gateway 3250S PC Desktop
It is running so slow!! It pauses and screen fades to light color! I cannont do my work!! Help!!
This could be for a couple of reasons, 1) you have a virus causing your laptop to crash or 2) you have a faulty Hard Drive.
Try downloading and running Hit Man Pro (an anti-virus software) that should clean up any viruses you have, download it here:
http://dw.com.com/redir?edId=3&siteId=4&oId=3000-2239_4-10895604&ontId=2239_4&spi=50fbf8256fc023103cca4ba60e4a71b1&lop=link&tag=tdw_dltext<ype=dl_dlnow&pid=11754089&mfgId=6302975&merId=6302975&pguid=CyZLHAoOYI4AAAxmYBAAAABD&destUrl=http%3A%2F%2Fdownload.cnet.com%2F3001-2239_4-10895604.html%3Fspi%3D50fbf8256fc023103cca4ba60e4a71b1
Run the scan and remove and viruses it finds and reboot the computer...see if this makes any difference, if not, try booting up in the recovery partition and repairing Windows.
Let me know if this helps
Mar 21, 2011 | HP Pavilion dv2310us Notebook
Slow computer
Corrupted System Files
Your computer slows due to corruptedsystem files. System files corruption is one of the most responsible causes forcrashing the entire computer. Deleting or moving the system files may crashyour computer.
1. Insert the Microsoft Windows Installation CD ROM.
2. Click Start ' Run.
3. Type SFC/ ScanNow and press ENTER.
4. Follow the instructions on your screen.
Corrupted Registry
System registry corruption leads to runtime errors and your computer slows.Windows Registry is very complex and not easy to repair manually. Hence, athird-party Registry Cleaner and PC Optimizer software is recommended.
1. Download a Registry Cleaner and PC Optimizer software such as Reginout.
2. Click Registry Cleaner tab.
3. Click Start Scan.
4. The registry scan will start. Wait till it is finished.
5. As per the results, click Fix Now button to start repairing you registry.
Often good registry cleaners include built-in Backup & Restore centre thatlets you recover from an unforeseen situation by simply restoring the state ofyour registry.
Faulty RAM
Your computer crashes due to problems with the computer memory. A faulty RAMmay result in Blue Screen of Death (BSOD).
In such a case, remove the existing RAM and clean it using a soft cloth. Then,connect it again. The problem may not persist..
Incomplete Installations
Your computer slows because of apreviously failed or incomplete installation. An incomplete or failedinstallation creates junk registry entries and thereby system crashing problem.
Repair the registry entries created by a failed setup and delete the files thatstill remain on your hard disk. Delete the contents of C:\Windows\Temp folder.
Disk Space Allocated by Unnecessary Files
Your computer slows if the operating system has no adequate free disk space toperform its operations. Temporary files, temporary internet files, log files,browser cache and other files may occupy a large amount of your disk space andthus generating runtime errors that crashes your system.
Using Disk Cleaner, delete the junk files from your hard disk. The steps are asbelow:
1. Click Start ' All Programs ' Accessories ' System Tools ' Disk CleanUp.
2. Follow the instructions on your screen.
Mar 10, 2011 | Dell OptiPlex GX620 PC Desktop
my pc is running slow
Hello
There could be several reasons for this:
[Software type]
1. There are too many trash files (temporary files left after some program crashes or uninstallation; temporary internet files and small amount of free memory after all)
2. Your computer Registry should be cleaned and optimized
3. Your hard disks should be defragmented
4. Some components have bad or corrupted drivers
5. Viruses, trojans and other malware may slow down your PC performance
6. Too many programs running at Startup or in your SysTray
7. Inacurate size of Virtual Memory
My advice would be to use this " Faster Computer Now" guide at:
http://tinyurl.com/yzvb3eg
[Hardware type]
1. If your computer wasn't fast from begining, consider upgrading RAM and/or Processor (see your computer mainboard's documentations for available options)
2. Hardware mullfunction
Of course there are more reasons, but I just mentioned mostly common
Jan 23, 2010 | Office Equipment & Supplies
527 people viewed this tip
David Payne
David Payne
