Tip & How-To about Computers & Internet
How To Do A eRecovery Reinstall to ACER Factory Defaults.
.Heres 2 Very Useful methods
1-ACERs Original (x4) Recovery Disk/s
or
2-ACERs preloaded eRecovery ,
DISK RECOVERY CD (x4)
Put in System CD
F1 to Access BIOS
Set Boot order to CD in BIOS
EXIT and SAVE ,CONFIRM ,YES.
On Restart RECOVERY Mode will commence.
Follow Prompts when asked and in this order,
RCD1,RCD2,RCD3
Last Disk will be System CD to close the program and save your new settings.
This completed will give you a fresh install of ACER's Preload.
When restarts let the System install everything before you try to use it.
The system will shut down and restart a couple of times so no rushing will fix your problems with a Factory Default Install.
It should take 45min to reinstall
ACER eRecovery Preloaded onto your machine
Open eRcovery thru ACER Empowering Technology
Select RESTORE
Choose Factory Default,
This process is about the same time frame (45Min),
as the 4 disk method I have listed in the discription above.
These will not work if you have a password locked on the bios or the hard drive so dont lose your passwords,
remember to kept them safe always.
Hope this clears any miss understanding of how to use eRecovery.
Enjoy Cheers MISTERDJ
Computers & Internet Logo
I need a acer aspire one happy recovery disk
The Acer Aspire One Netbook has a hidden partition on its hard disk drive which allows recovery of
1. operating system to original factory image (with no recovery disk required)
2. applications (selectable)
3. drivers (selectable)
If the netbook came with pre-installed Windows XP, use Acer eRecovery Management by
1. pressing start button at bottom left corner of Taskbar
2. hover cursor over All Programs then Acer Empowering Technology
3. then click on Acer eRecovery Management and follow subsequent recovery instructions
Alternatively, on powering up, press Alt and F10 together while Acer logo is showing.
If this doesn't work, there is the possibility that the D2D recovery is not enabled for startup.
To enable D2D recovery,
1. press F2 on powering up to get into the startup utility
2. cursor over to the Main tab
3. cursor down to D2D and enable it.
4. save changes when exiting - system will reboot
5. again, press Alt and F10 together while Acer logo is showing.
Jan 15, 2011 | Acer Aspire One Netbook 8.9" Notebook
how do I do a full recovery with the disc
Turn your computer on.
Insert the Disk and choose to enter BIOS, should be F2 but watch the screen to see the right function key.
Change the boot device order to: CD-ROM, HDD in that order.
Save changes and restart the computer.
The Recovery Disk would boot up and a wizard will guide you through the recovery process.
Follow the instructions to recover your computer.
Apr 03, 2010 | Acer Aspire 3050-1733 Notebook
MY COMPUTER CRASHED GOT MOST OF THE DATA BACK BUT NEED THE START UP DISK
as far as I know Acer does not supply start up cd's but a recovery copy the entire operating system along with original programs are on your hard drive in a hidden partition. To recover the original factory install...
1 Boot to Windows XP.
2 Press <Alt> + <F10> to open the Acer eRecovery Management utility.
3 Enter the password to proceed. The default password is six zeros.
4 In the Acer eRecovery Management window, select Recovery actions and
click Next.
5 In the Recovery settings window, select Reinstall applications/drivers and
click Next.
6 Select the desired driver/application and follow the instructions on screen
to re-install.
Last resort get out your manual or download the manual from Acer.
Dec 12, 2009 | Acer Aspire 5610-4648 Notebook
install the eRecovery drivers for aspire 5715Z
First ensure you have enabled D2D from Bios, If bios settings are OK then that message often comes up when E recovery partition is damaged.
Possible solutions are calling Acer and getting a disk to restore recovery partition (best way to proceed)
Or downloading and installing drivers from acer website
Here is recovery procedure from manual, to ensure you are doing corrrectly:
Create backup
You can create and save backup images to hard disk, CD or DVD.
2 Press Alt + F10 to open the Acer eRecovery Management utility.
4 In the Acer eRecovery Management window, select Recovery settings and
click Next.
5 In the Recovery settings window, select Backup snapshot image and
click Next.
6 Select the backup method.
a Use Backup to HDD to store the backup disk image on drive D:.
b Backup to optical device to store the backup image on CD or DVD.
7 After choosing the backup method, click Next.
Follow the instructions on screen to complete the process.
Restore from backup
You can restore backups previously created (as stated in the Create backup
section) from hard disk, CD or DVD.
click Next.
5 Select the desired restore action and follow the onscreen instructions to
complete the restore process
Here Acer download page: Acer Service & Support
May 05, 2009 | Computers & Internet
1,898 people viewed this tip
David Payne
David Payne
