Tip & How-To about Computers & Internet
CONFIGURING YOUR SYSTEM FROM HOME FOR XP
For you to sit at home for your system configuration on how to setup your xp program
1. When you run the Windows XP Professional Setup program, you must provide information about how to install and configure the operating system. Thorough planning can make your installation of Windows XP Professional more efficient by helping you to avoid potential problems during installation. An understanding of the configuration options will also help to ensure that you have properly configured your system.
I won't go into that part right now but here are some of the most important things you should take into consideration when planning for your XP installation:
* Check System Requirements
* Check Hardware and Software Compatibility
* Determine Disk Partitioning Options
* Choose the Appropriate File System: FAT, FAT32, NTFS
* Decide on a Workgroup or Domain Installation
* Complete a Pre-Installation Checklist
After you made sure you can go on, start the installation process.
2. Beginning the installation process
You can install Windows XP in several methods - all are valid and good, it all depends upon your needs and your limitations.
* Manual installations usually come in 3 flavors:
* Boot from CD - No existing partition is required.
* Boot from the 6 Setup Boot Disks, then insert the CD - No existing partition is required (see the Create Setup Boot Disks for Windows XP page).
* Boot from an MS-DOS startup floppy, go to the command prompt, create a 4GB FAT32 partition with FDISK, reboot, format the C partition you've created, then go to the CD drive, go into the I386 folder, and run the WINNT.EXE command.
* Run an already installed OS, such as Windows NT 4.0 Server. From within NT 4.0 go to the I386 folder in the W2K installation CD and run the WINNT32.EXE command.
* If you want to upgrade a desktop OS such as Windows 98 into Windows 2000 Professional you can follow the same procedure as above (You cannot upgrade Windows 98 into W2K Server).
There are other non-manual installation methods, such as using an unattended file along with a uniqueness database file, using Sysprep, using RIS or even running unattended installations from within the CD itself, but we won't go into that right now.
It doesn't matter how you run the setup process, but the moment it runs - all setup methods look alike.
3. The text-based portion of the Setup program
The setup process begins loading a blue-looking text screen (not GUI). In that phase you will be asked to accept the EULA and choose a partition on which to install XP, and if that partition is new, you'll be asked to format it by using either FAT, FAT32 or NTFS.
i. Start the computer from the CD.
ii. You can press F6 if you need to install additional SCSI adapters or other mass-storage devices. If you do you will be asked to supply a floppy disk with the drivers and you CANNOT browse it (or a CD for that matter). Make sure you have one handy.
iii. If you want, you can press F2 to run the ASR sequence. For that you need a good backup created by the Windows XP backup program, and the ASR floppy disk. If you plan to install a new copy of XP - don't do anything.
iv. Setup will load all the needed files and drivers.
v. Select To Setup Windows XP Professional Now. If you want, and if you have a previous installation of XP, you can try to fix it by pressing R. If not, just press ENTER.
vi. Read and accept the licensing agreement and press F8 if you accept it.
vii. Select or create the partition on which you will install Windows XP Professional. Depending upon your existing disk configuration choose one of the following:
viii. If the hard disk is unpartitioned, you can create and size the partition on which you will install Windows XP Professional.
ix. If the hard disk is already partitioned, but has enough unpartitioned disk space, you can create an additional partition in the unpartitioned space.
x. If the hard disk already has a partition that is large enough, you can install Windows XP Professional on that partition. If the partition has an existing operating system, you will overwrite that operating system if you accept the default installation path. However, files other than the operating system files, such as program files and data files, will not be overwritten.
xi.If the hard disk has an existing partition, you can delete it to create more unpartitioned space for the new partition. Deleting an existing partition erases all data on that partition.
If you select a new partition during Setup, create and size only the partition on which you will install Windows XP Professional. After installation, use Disk Management to partition the remaining space on the hard disk.
4. Select a file system for the installation partition. After you create the partition on which you will install Windows XP Professional, you can use Setup to select the file system with which to format the partition. Windows XP Professional supports the NTFS file system in addition to the file allocation table (FAT) and FAT32 file systems. Windows Server 2003, Windows XP Professional, Windows 2000, and Windows NT are the only Microsoft operating systems that you can use to gain access to data on a local hard disk that is formatted with NTFS. If you plan to gain access to files that are on a local Windows XP Professional partition with the Microsoft Windows 95 or Windows 98 operating systems, you should format the partition with a FAT or FAT32 file system. We will use NTFS.
i. Setup will then begin copying necessary files from the installation point (CD, local I386 or network share).
ii (or if setup was run by booting from CD) the copying will probably last a few minutes, no more than 5 max.
iii. The computer will restart in graphical mode, and the installation will continue.
iv.The GUI-based portion of the Setup program
The setup process reboots and loads a GUI mode phase.
It will then begin to load device drivers based upon what it finds on your computer. You don't need to do anything at this stage.
i. Click Customize to change regional settings, if necessary.
ii. Current System Locale - Affects how programs display dates, times, currency, and numbers. Choose the locale that matches your location, for example, French (Canada).
iii.Current Keyboard Layout - Accommodates the special characters and symbols used in different languages. Your keyboard layout determines which characters appear when you press keys on the keyboard.
If you don't need to make any changes just press Next.
If you do need to make changes press Customize and add your System Locale etc.
Note for Hebrew users: Unlike W2K, it is SAFE and it is OK for you to install Hebrew language support at this phase.
To install Hebrew support:
After pressing Customize go to the Languages tab and select the "Install files for complex script and right-to-left languages".
A warning message will appear. Press Ok.
Warning: You must now press Apply!!!
Setup will copy the necessary files from the installation point.
You can now go to the Regional Options tab and select Israel in the Location drop-down list, and Hebrew in the Standards and Formats drop-down list. Click Ok.
1. Type your name and organization.
2. Type the product key.
3. Type the computer name and a password for the local Administrator account. The local Administrator account resides in the SAM of the computer, not in Active Directory. If you will be installing in a domain, you need either a pre-assigned computer name for which a domain account has been created, or the right to create a computer account within the domain.
4. Select the date, time, and time zone settings.
5. Setup will now install the networking components.
After a few seconds you will receive the Networking Settings window. BTW, if you have a NIC that is not in the HCL (see the What's the HCL? page) and XP cannot detect it, or if you don't have a NIC at all, setup will skip this step and you will immediately go to the final phase of the setup process.
Press Next to accept the Typical settings option if you have one of the following situations:
* You have a functional DHCP on your network.
* You have a computer running Internet Connection Sharing (ICS).
* You're in a workgroup environment and do not plan to have any other servers or Active Directory at all, and all other workgroup members are configured in the same manner.
Computers & Internet Logo
problem setting up sky broadband on windowsw xp professional
Hi Robert,
Are you aware that Windows XP will no longer be supported by Microsoft after April 2014 and will then be open to hackers worldwide, it is highly recommended to upgrade to Windows 7 on all PCs and devices. Could be Sky are ahead of the game and have already dropped XP.
Dec 04, 2013 | Microsoft Windows XP Professional for PC
Windows XP download
Windows XP Professional SP2
http://www.microsoft.com/downloads/details.aspx?FamilyId=535D248D-5E10-49B5-B80C-0A0205368124&displaylang=en
Step 2: Run the Setup disk program to create the Setup disks
When you download the Setup disks, the download contains only one large program file. When you run the downloaded file, it extracts the files. You receive the following message:
This program creates the Setup boot disks for Windows XP. To create these disks, you need to provide 6 blank, formatted, high-density disks.
Please specify the floppy drive to copy the images to:
Type the drive letter for the floppy disk drive (this is typically drive A). After you type the floppy disk drive letter, you receive the following message:
Insert one of these disks into drive drive letter:. This disk will become the Windows XP Setup Boot Disk.
Press any key when you are ready.
When you press a key, the downloaded file starts to extract and copy the files. Continue to insert the blank disks as you are prompted to do this until all six disks are created. If the process is interrupted, you must run the downloaded program file again to create all six disks.
Make sure that you label each disk appropriately with the number that is specified by the program. You must use the disks in the correct order during the Setup process.
Step 3: Start your computer by using the first Setup disk to begin a new Windows XP installation
After you create all six disks, insert the first disk in the floppy disk drive, and then restart the computer. The computer must be configured to start from the floppy disk drive. You may have to modify the BIOS settings on your computer to do this.
The Setup process starts. Insert the other floppy disks when you are prompted. You must use the Windows XP CD-ROM to finish the Setup process.
hope it helps
May 13, 2012 | Microsoft Windows XP Professional With...
Will not function with Windows 7, what is wrong?
Not all programs that worked in Windows XP will run in Windows Vista or Windows 7.
I suggest you try compatibility mode to see if it helps.
If the program is not compatible, then you may try to install and run the program in compatibility mode.
Use the following steps:
1) Right click on the Program
2) Click on Properties
3) Click on Compatibility tab
4) Select Run this program in compatibility mode and select Windows Vista or whatever operating system the program was running successfully.
Refer to the link here: Make older programs run in this version of Windows
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
If the compatibility is not successful, then try and runthe Program Compatibility troubleshooter:
1. Open the Program Compatibility troubleshooter by clicking theStart button.
Then click Control Panel. In the search box, type troubleshooter, and then clickTroubleshooting. Under Programs, clickRun programs made for previous versions of Windows.
2. Follow the instructions in the troubleshooter.
If you cannot install a program, insert the installation disc for the program and, using the troubleshooter, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The troubleshooter is not designed to work on programs that have an .msi file name extension.
If you run Windows 7 Professional or Ultimate version, install Windows Virtual PC and Windows XP mode (http://www.microsoft.com/windows/virtual-pc/default.aspx) and execute your software in Windows XP.
If you run Windows 7 Home Premium, try VirtualBox (www.virtualbox.org) or VMware Player (www.vmware.com) and install a separate copy of Windows XP (either Home Edition or Professional) for that purpose.You can find virtualization software free of charge that will run on Windows 7 Home Premium.
Hope this helps.
Oct 28, 2010 | MGI Software PhotoSuite 3 for PC
i want to change my windows xp to Home edition
You can also do a clean installation by following the procedure as listed below:To perform a clean installation of Windows XP, follow these steps:Back up all important information before you perform a clean installation of Windows XP. Save the backup to an external location, such as a CD or external hard disk.Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
Note To boot from your Windows XP CD, the BIOS settings on your computer must be configured to do this.When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.At the Welcome to Setup screen, press ENTER to start Windows XP Setup.Read the Microsoft Software License Terms, and then press F8.Follow the instructions on the screen to select and format a partition where you want to install Windows XP.Follow the instructions on the screen to complete the Windows XP Setup.
Oct 27, 2010 | Microsoft Windows XP Professional
sata
You must disable the native mode for the SATA in setup mode.
***NOTE*** be sure that you have all of your drivers for the SATA and all drivers for windows xp before beginning.
Mar 12, 2008 | Computers & Internet
163 people viewed this tip
David Payne
David Payne
