Tip & How-To about Kitchen Ranges
Surface Burner Replacement on Electric Smooth Top Range
Steps necessary to replace one of the surface elements on a smooth top electric range.
Before you begin:
1. UNPLUG the range before servicing.
2. There are a few screws located under the front edge of the cook top. You will need to open the oven door to see them. Remove these screws and the top should lift up.
On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, Follow these steps:
a. Unplug the cook top and leave the elements in place.
b. Place the whole cook top assembly face-down on a soft surface (like some old towels, or a blanket).
c. Remove the bad surface element by removing only the bracket pair that the affected element is attached to. Leave the rest of the elements wired together. Write down the wire color codes so you can be sure the new element is installed correctly. HINT: A digital camera can save you some time.
d. When installing the new surface element, make sure you use the same alignment marks (the numbered positions around the perimeter) as the old element. Avoid touching the burner surface and handle with care. Try to handle from the underside of the element only.
If the wiring harness does NOT unplug, prop the cook top in place and install the surface element from underneath. A helpful hint: Use some duct tape to hold the assembly until you have screwed it back into place. Don't forget to remove the duct tape when completed.
Kitchen Ranges Logo
how do i replace the surface element for a glass top cook top range
The cook top on this model range will lift up, exposing the surface burners and wiring harness. The screws are located along the bottom of the front edge of the cooktop. You will need to open the oven door to see them. Then, just follow these steps:
Before you begin:
1. UNPLUG the range before servicing. There is dangerous voltage still present even with burners turned off.
2. There are a few screws located under the front edge of the cook top. You will need to open the oven door to see them. Remove these screws and the top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
d. When installing the new surface element, make sure you use the same alignment marks (the numbered positions around the perimeter) as the old element. Avoid touching the burner surface and handle with care. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure. The elements are fragile.
If you have any questions about this repair, please let me know. You can reference searspartdirect.com for some helpful exploded view diagrams of you range for assistance if you need it. I hope you find this information helpful.
Nov 17, 2009 | Whirlpool RF364 Electric Kitchen Range
Opening the cook top in a Whirlpool electric range
The cooktop on this model range will lift up, exposing the surface burners and wiring harness. The screws are located along the bottom of the frotn edge of the cooktop. You will need to open the oven door to see them. Just follow these steps:
Before you begin:
1. UNPLUG the range before servicing. There are dangerous voltages still present even with burners turned off.
Nov 12, 2009 | Whirlpool RF378 Electric Kitchen Range
how to replace the glass for whirlpool oven serial # RPO 713144
This advice is for Electric Ranges equipped with glass smooth tops. If it becomes necessary to replace the cook top due to wear or damage, here's some helpful tips on how to complete the repairs yourself. NOTE: Cook tops are NOT cheap. Prices vary between models, but most are in the $200 to $300 range. With added labor charges, this repair can cost over $600 from an appliance repair company.
WARRANTIES: Most warranties DO NOT cover cosmetics. That is, if your cooktop paint starts to wear off, most manufacturers will not replace it. Warranties also DO NOT cover accidents such as dropping something on the top and breaking it. Warranties DO cover blistering, warping and heat related breakage (if you are using the recommended cookware). This is why it is important to follow all the manufacturer's use and care instructions that come with your range. I know this does not include ALL manufacturers, but this is true with most.
This is a recommended two-person repair job. Please read through the instructions carefully before starting the repairs, and follow any safety recommendations.
2. If the old cook top is broken, you will need to get rid of a much of the glass shards as you can and thoroughly vacuum the area around the oven box. Use extreme care when handling broken glass. Wear safety glasses and gloves.
3. There are a few screws located under the front edge of the cook top. You will need to open the oven door to see them. Remove these screws and the top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
4.On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, Follow these steps:
1. Unplug the cook top and leave the elements in place.
2. Place the whole cook top assembly face-down on a soft surface (like some old towels, or a blanket).
3. Remove the surface element assembly leaving all the elements wired together.
4. Place the new cook top face down in the same manner and lay the surface element with wiring harness directly on to it and screw in place.
5. Install the new cook top back on the range and you are DONE.
5. If the wiring harness does NOT unplug, follow these steps:
1. There are a series of screws holding the element assemblies in place. Leave these assemblies wired together for ease of replacing. It is recommended that a second person holds the assemblies in place to support the wires until all the screws have been removed.
2. Lay the intact element assembly, with wires still connected, on top of the oven box. Handle the surface elements with care. They are very fragile. Care also must be taken not to handle the element coils or ceramic material. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure.
3. If you have to remove the elements, individually, make sure you write down how the wires were connected to ensure you reconnect them in the right order. Make sure you also take note of the numbering scheme on the element and make sure you place the mounting brackets in the same holes that they came out of. Use care when screwing into the new cook top. CAUTION: The screw holes are usually painted and a little force may be required to thread the screws. Do not apply too much pressure on the glass, or you can damage it.
4. Prop the new cook top in place and install the surface element assembly from underneath. A helpful hint: Use some duct tape to hold the assembly until you have screwed it back into place. Don't forget to remove the duct tape when completed.
5. Lower the new cook top into place and secure with screws.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 05, 2009 | Whirlpool SF367 Gas Kitchen Range
I have a Kenmore electric range oven Model # 79095201103 that has a glass top. The top cracked and I ordered a new glass top for it. What steps do I need to do to replace the top. Is it complicated???
Here ya go...
Good luck and I hope this helps.
Apr 06, 2008 | Kitchen Ranges
479 people viewed this tip
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
