Tip & How-To about Cell Phones
How to refresh your cell phone battery
If the battery is acting weak pull the battery and hold out for about 20 seconds then re-install. Frequently that will reset the battery and it will act like a new one again.
Cell Phones Logo
How do I hard reset my lg290cm?
Before you do master reset. Try to switch off your phone and remove the battery. Leave it for an hour or more then you can switch it on back again. It this doesn`t work the you will have to do a master reset. There are several ways to do this using physical keys. Below are some ways to do it. Hold Volume + and power for 20 seconds Hold Volume - and power for 20 seconds Hold Volume + and power for 20 seconds Hold volume + and home and power for 20 seconds Hold reset button for 30 seconds. Hold Volume - and home and power for 20 seconds. these will all do a hard reset. you can also locate a tiny hole around your phones cover pressing it for 20 seconds. Let us know if it works!
Jul 29, 2014 | Net10 LG290C Pre-Paid Cell Phone
My eton E5 will not reset when I press the reset button.
Unplug the AC adapter. Remove the batteries. Press & hold down any front panel button for about 10 seconds. Repeat for any 2 more buttons. Then reset with the paper clip. Do not install weak batteries, or try to restart or reset the radio after it shut off because of weak batteries. Weak, dead, or shorted batteries, tend to make the processor inside or the reset function to screw up.
Oct 18, 2013 | Eton E5 Radio
My Eton E5 will not reset when I put a paper klip in the reset hole.
bypass dell secure manager on latitude e6510
The previous owner has locked the laptop via the BIOS - you'll need to reset the BIOS to fix this - to reset the BIOS you will need to unplug, remove battery, open bottom of case remove the CR2025 (wafer type) battery and locate the small reset button, hold button down 20 seconds replace CR2025 battery (and recommend replace with new), hold reset button again for 20 seconds) - replace bottom cover. install battery and you should now be dealing with the not knowing the Windows Log In password (which I can't help you with).
Apr 05, 2013 | Dell Computers & Internet
How do I reset it?
STEP 1 – Reset the device
  1. Slide the Power switch up and hold it for approximately 20 seconds.
  2. Release the Power switch once the device is powered down.
  3. Turn the device back on.
STEP 2 – Download and Install the Sansa Firmware UpdaterSTEP 1 – Reset the device
This is what I found on a Frequently Asked Questions page #13. The link is here below
http://www.sansa.com/support/sansa_view/faqs
You may need to scroll through to the one I found. Hope this help :D
Jun 06, 2009 | SanDisk Sansa e250 MP3 Player
1,234 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
