Tip & How-To about Refrigerators
What is Freezer Burn?
Is a condition that occurs when frozen food has been damaged by dehydration and oxidation, due to air reaching the food . It is generally induced by substandard (non-airtight) packaging. Freezer burn happens when air is exposed to your frozen food, and the water in both the air and the food, or just in the food, re-distributes itself. If the food you froze happens to have a lot of fat in it, the freezer burn can get even worse, and actually oxidize in the dry spots, leaving what was once a delicious roast a dry, gray piece of meat.
While freezer burn will not hurt you, it makes food look and taste a lot less appetizing. Here's how to avoid having those weird dry gray patches appear on that steak you saved for a special occasion.
There are some tips someone has to have in mind to prevent this problem.
1) Try to get all the air out of packages before you freeze them. The freezer burn will happen in those tiny pockets of air.
2) Keep the freezer door closed. If you have a family member that tends to open the freezer, then go off and do something in the kitchen while the door is still open, try to break them of the habit. This also applies to anyone who opens the door just to stare into the frozen chamber for five minutes hoping to find something to eat.
3) Let any food you do freeze cool to room temperature before you store it, but try not to let it sit for more than 30 minutes before you pack it up for storing.
4) Keep your freezer temperature constant. A few degrees below 0 are ideal. Freezer burn only happens at 1 degree and above. Lots of freezer burn can be a sign of a freezer that is on the fritz.
5) make sure all seals are closed. If you don't trust a package or you really want to make sure something doesn't get freezer burn, put it inside a second container or wrap it in tin foil.
6) Soups and stews and other liquids need some "give" in their packaging to allow for the liquid to expand and contract as it freeze and thaw. Put a piece of plastic wrap over the top of soups, just under the container cover, to let the expansion happen without exposing the soup to the air.
7) Leave space between your frozen items so the air can circulate.
8) Do not over stuff your freezer. Putting any more than 2 to 3 pounds of food for every cubic foot of freezer space is asking for freezer burn.
The chemistry behind freezer burn is called sublimation. It’s when water goes from a solid directly into a gas. You can see sublimation on a warm day after it has snowed. The water vapor rising up from the snow piles is sublimating -- going directly from a solid into a gas (water vapor) -- entirely skipping the liquid phase? www.victorwod1234.blogspot.com
Refrigerators Logo
What do you think about best organic mattress?
There are lots of internet sites online which can be supplying info associated with best organic mattress. These are generally specifically manufactured for those people who are supplying details information about greatest food dehydrator. For more information please visit this website: http://parentsneed.com/top-5-best-food-dehydrators-for-your-family/ ParentsNeed Top 5 Best Food Dehydrators for Your Family 2016 Reviews
Nov 08, 2016 | Furniture
What is a Food Dehydrator?
Wikipedia says: a food dehydrator refers to a device that removes moisture from food to aid in its preservation. A food dehydrator uses a heat source and air flow to reduce the water content of foods.
Feb 18, 2013 | Kitchen Appliances - Others
Is there a difference between freeze-dried and dehydrated food?
Yes there is, in freeze-drying process they use a cold temperature and in dehydrated food they use warm temperature. In the freeze-frying process the fresh foods are frozen first then the moisture removed in a vacuum chamber and since the food remains frozen during the process, the food's cell structure don't change.
Aug 09, 2012 | Camping, Backpacking & Hiking
What is the difference between freeze-dried and dehydrated food?
Freeze-dried food is quickly frozen and placed in a strong vacuum. This process uses low heat and causes less harm to the tissue, taste and smell of the food. To dehydrate food, heat is applied and moisture is removed through the process of evaporation. This is a low cost method in comparison to freeze-drying.
Jul 31, 2012 | Camping, Backpacking & Hiking
285 people viewed this tip
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
