Tip & How-To about Refrigerators
REFRIGERATOR APPLIANCE REPAIR HELP & PARTS
Here are some things you have to know about freezer and refrigerators.
If you see Frost build up on the back wall of the freezer you might have a defrost problem. The Basic defrost system is: Your heater, your limiter, and timer if any of these fail you should get an even frost on the back wall (Most side by side Refrigerators and Top mount models ) Note: (depending where your evaporator is located). If you have no idea what I'm talking about you should call for a repair person. On the other hand if you get the Idea let me help a little more! You can check your heater and limiter with a multi-meter. You must have the component disconnected and the limiter has to stay cold to test it! The timer can't always be tested and comes in many new forms. it could be part of the main control, or an old mechanical timer or just a electronic timer.
Your Evaporator Fan Might not be working, this fan blows the cold air from your freezer to your Fresh food compartment. You can listen in your freezer area to hear if the fan is on. You might half to push the freezer door buttons in to activate the fan. If your machine is in defrost mode the fan will not come on, so if your fan is not on just check it in about 45 min and if it is still not coming on then your fan is probably bad.
If you have a electronic damper door it could be in the closed position, preventing the air flow from the freezer side to the fresh food side. This means your thermostat could be bad, a sensor or main control board could be bad.
Question: Why are the Fresh food side and Freezer are warmer?
Your condenser coils could be dirty or Condenser Fan could be bad, this will cause your compressor to overheat and shut down causing your Refrigerator to quit cooling until the compressor has cooled down. In some refrigerators a good quick way to tell if your system is getting too hot is too feel the strip between the fresh food door and the freezer door, if this strip is hot your compressor could be overheating. Something you can do if you feel that center strip is hot , take a fan and put it facing the bottom of the refrigerator and see if that strip doesn't get cooler in about 45 min. This is only to help you till you get a repair person out to look at it.
There are many other reasons for this type of problem: Intermittent compressor start device, Intermittent Thermostat, Electronic control board problems, Electronic Thermostat problems.
One more important note to all: Freon does dissipate it can only leak. This means there has to be a hole! Filling your machine back up without fixing the hole will not fix your machine. It might run for a day a week maybe a month or a year but it is not fixed. This goes for refrigerators, freezers and Air conditioners. Don't let anyone tell you it just needed a little Freon. Your leak might be small enough for it to work for a month and then you loose all your food again!
Question: Why is my ice maker won't make any Ice?
Answer: The ice system in most Refrigerators consists of: The Ice maker itself, the water inlet valve, The Dispenser System, and the lines that carry the water.
There are many different designs.
Example: Is your ice dispenser tray in your side by side door? If it is, you might have a emitter board that detects the level of your ice bucket. This emitter board commonly fails and needs replaced to restore function to your ice maker. If you have this design check the kick plate of the machine for the Tech sheet, this sheet will help you determine your problem.
A common problem with most ice maker systems is the water valve has a slow leak and freezes the water inlet tube to the ice maker, causing the ice maker not to receive water. In this case you need to replace the water valve or the water valve simply is bad. you will half to defrost the tube if it was frozen and make sure you replace the valve.
Have you check your water filter on your refrigerator? This also can cause a problem with your ice maker and water dispenser.
Good luck with your repair.www.victorwod1234.blogspot.com
Refrigerators Logo
Frig has suddenly become warmer than usual. Freezer is at 20 degrees and frig at 60. Tried to vacuum coils but very dificult to reach them underneath the unit. Any other hints?
what the problem most likely is a failed part of the defrost system Do you see a bunch of frost built up on the back wall of the freezer? If you do frost build up, take off the back wall of the freezer and replace the defrost heater and defrost thermostat. A hair dryer could be used to melt the built up frost from the coil behind the back wall. Another part that will cause frost build up is the defrost control, that isn't the freezer behind the back wall but instead it is part of the main computer board on the back of the refrig. I would replace heater/defrost thermostat first though, since they are the most likely to fail parts.
I hope my answer will help you to fix your refrigerator,
Gene
Aug 05, 2011 | Whirlpool GS6NBEXR Side by Side...
freezer is cold but refrigerator side is barely cooling. turned off and water leaking out of door on the freezer side
Hello Roxanne,
what the problem most likely is a failed part of the defrost system Do you see a bunch of frost built up on the back wall of the freezer? If you do frost build up,i would take off the back wall of the freezer and replace the deforst heater and defrost termination. A hair dryer could be used to melt the built up frost from the coil behind the back wall. Another part that will cause frost build up is the defrost control, that isn't the freezer behind the back wall but instead in the fresh food compartment in the control panel where the thermostat is. I would replace heater/defrost termination first though since they are the most likely to fail parts.
Gene
Aug 05, 2011 | Maytag MZD2766GES Side by Side...
Hello, our freezer is working fine so far but the fridge is not.
The first thing you should be looking for is a frost or "snowy" build up on the back wall of the freezer. Assuming that there is a build up then you need to remove the back wall of the freezer. Gaining access to the defrost thermostat and defrost heater is a little difficult due to the frost build up. the defrost thermostat is attached to the evaporator coils to the right of the fan assembly. You need to check for continuity across the thermostat. The thermostat is the most likely cause.
Jan 11, 2011 | Kenmore 62832 / 62834 / 62839 Bottom...
fridge side not working freezer frost on back at first now not freezing hardly at all
If you still have the frost build up on the back wall of the freezer, your problem is in the defrost circuit. You'll find a bad heater, terminator or control.
Also verify operation of the evaporator (freezer) fan.
Apr 29, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
The thermostat is not functioning the way it should leading to frost build up. You need to replace it. Should cost you around 40$
Sep 02, 2008 | GE GSS20IEM Side by Side Refrigerator
264 people viewed this tip
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
