Tip & How-To about Televison & Video
LG 42" PLASMA TV CLICKING WILL NOT TURN ON REPAIR
Hi
Ok everyone, this is a very common fault on this model of tv power supply, just keeps clicking on and off.
Your power supply board number should be.. 6709900019A
To resolve the issue we need to change some bad capacitors in the supply these are all the same value 3300uf / 10v
C227 / C201 / C202 / C203 / C281 / C282 / C283 / C271 / C272
All these need to be changed for the same uf but try and use a higher voltage, lets say 3300uf / 25v
Upon replacement your power supply will be like new and your tv will fire straight up.
Hope this helps a few people
Televison & Video Logo
Can a novice replace defective power board?
Hi Claudia,
everyone has to start somewhere, replacing a Power Supply Board is quite straightforward with a little common sense and safety precautions, there are many tutorials on you tube, you would probably find that someone has posted a tutorial on your actual model, here's an example of a power supply board swop, have a look at this one and others to gain an insight and decide then if its for you,
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Feb 12, 2016 | Sceptre X405BV-FHD3 40 in. LCD HDTV
clicks and clicks but wont power on
Hi.
The TV is in forced standby because an internal fault has been detected. The clicking is the protection circuit that prevents the TV from starting to avoid more damage to internal parts.
You can try disconnecting power cord for ten minutes but I doubt that this will fix the problem. When the TV is in protect mode (that is the name for the "clicking and no power on") repair is usually needed. Testing will start from PSU to inverter passing through main controller board. One of the most common faults affecting this TV is the power supply, but all parts must be tested.
If you want to call a technician ring your local Samsung Support number.
Regards.
Ginko
Sep 06, 2011 | Samsung LN-T4053H 40 in. LCD Television
Hi there I have a lg 50" plasma Model DPD50X30010. It does not turn on. When I power it up it clicks and then clicks again and Turns off. Could that be the power supply need help
Yes,it the power supply board.If u know basic electronic's,have tools and know how to do basic soldering?Take the tv aparts.The tv power supply board,that the board,where the power a/c cord plug into it.Searches the power supply board,look for those dying leakages of gases,going to be dead parts call capaitors.They alway bulges up on it tops or puffing up on it tops.Replaced these dying,going to be dead capacitorsThe tv power will be stable again and work.Or tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Aug 02, 2010 | LG 50PX1D 50 in. Plasma Television
tv clicks on but no picture yhe stand by light is bliking i have unpluged the tv from wall and the cable box but it justs click when you turn it on no picture could the settings be on
Hi .
The clicks that you hear is an internal device called protection circuit that is shutting down the TV, and forcing the PSU to +5V low only to keep the TV in standby.
That is called protect mode.
If the TV stays in stand-by, with the LED light on, but does not respond to remote, or to the buttons on the chassis, then that means that the TV has gone in protect (safe) mode because an internal fault had been detected.
In that case the TV is usually faulty.
The fuse on the PSU board is not causing protect mode. When the fuse has blown , then the unit stays completely off.
Common faults on rear projection models are Electrolytic capacitors on PSU board (power board), convergence ICs (convergence board). The parts must be tested before replacement. Less common faults could cause the same problem.
Try first disconnecting all connected devices, and leaving the TV disconnected from power for about 30 minutes. To drain power completely.
You cabn follow the basic troubleshooting on this article: Why my TV does not start up and remains in...
If that does not work, contact Sony, ringing the support number listed on the owners manual to get the TV repaired by a licensed technician.
Regards.
Apr 09, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
817 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
