Tip & How-To about Computers & Internet
How to connect to always automatically connect to your SSID
Ever turn on your computer and try to connect to the internet? Ever see all the many SSIDs in your neighborhood listed in your wireless radar or your "Windows Wireless Connection". Then you'd scroll down to double click on your SSID so that you can connect to the internet. Imagine doing this everytime you have to connect to the internet. Wouldn't that be annoying?
The Objective
The objective of this Tip/How-To is to have you turn on your computer and connect to the internet automatically via your SSID (Wireless Network Name). Hence, you wouldn't need to manually find your SSID everytime you need to connect to the internet.
Pre-requisites or Must haves for this Tip to work
  1. A computer with a wireless adapter
  2. A wireless router
  3. An active internet service
  4. This tip is designed for Windows XP. I will post one up for Windows Vista and Windows 7.
  5. This tip is designed to work with Wireless Networks (SSID) that do not have any passwords or encryption.
Active Tip Dictionary (throughout this TIP)
SSID
is the technical term for your broadcasted network name. This is basically what you will see listed in your WIRELESS NETWORK CONNECTIONS manager.
To make your computer connect automatically to the internet via your SSID, we will need to manually tell your computer to connect to your SSID and then we will need to save this setting so that your computer will automatically connect to your SSID everytime you turn on your computer.
Let's Begin.
Start your computer by turning it on.
Click on your Start Button.
Move your mouse over to Control Panel and then left click on it.
Double click on the Network Connections icon.
Double click on Wireless Connection. Now in the picture above you see Wireless Connection 3 but on your screen you should see Wireless Connection.
Now click on Properties.
Click on the Wireless Networks Tab.
Now scroll up and down under Preferred networks until you find your Wireless Network Name (SSID). For me, it's called linksys therefore I will select linksys.
Now click on the Connection tab.
Under Automatic connection, click to check "Connect when this network is in range". This will tell your computer to connect automatically to your Wireless Network Name (SSID).
Click OK to save this setting.
Click OK again to get out of the Properties window.
Click OK again to get out of the Wireless Connections window.
Then click Close to close out of the Wireless Connections window.
And there you have it, you have setup to automatically connect to your Wireless Network (SSID) everytime you turn on your computer.
Now restart your computer and give it a few seconds, and voila, you are automatically connecting to your Wireless Network (SSID). Now you can surf the internet. You can set this on all your computers at home that have a wireless card.
Remember to give me a good rating and vote for me. If you require further tips and tricks, feel free to contact me through the contact box. I will post up your tip.
Computers & Internet Logo
making unusual alerts with Ka and x bands
It could be picking up garage door openers, which are a common false alert for radar detectors. In a neighborhood, there are all sorts of sensors that give off false alarms. I usually turn mine off when driving through a neighborhood as police are less likely to be using radar (unless in a school zone).
Apr 02, 2014 | XRS-757 Radar Detector
Where is the SSID number
follow this steps and fix it. God bless you
  • Download a program that will scan your network for hidden SSIDs. Many free utilities are capable of doing this, including inSSIDer, NetStumbler and or Kismet (see Resources). Only inSSIDer will show the hidden SSID. NetStumbler and Kismet will find networks with hidden SSIDs and display most of their information, but list the SSID as "Unknown."
  • 2
    Run the program and click the "Scan Now" or "Scan" button. The program will scan your wireless network for all signals coming from other networks, both hidden and broadcasting their SSIDs.
  • 3
    View the list of networks that appears when the scan concludes. All networks within range of yours will appear on the list. Compare the list with the list of wireless networks that your computer routinely picks up to determine which are hidden and which were already broadcasting their SSIDs.
Sep 20, 2013 | ZTE Warp
is there anyway to keep other peoples wireless internet connections from showing up on my computer
Unfortunately no, the wireless signals that your computer is picking up are openly being broadcast with their SSIDs available to be seen. It is a radio signal, just like on the radio in your car, you will not be able to block radio stations. The best suggestion is to just connect to your wireless connection and don't worry about the others as they are not hurting anything.
Aug 19, 2011 | Linksys Cable/DSL 802.11n Security Rtr...
how do i find the SSID on my computer
Click on the icon located on the lower right corner of the desktop window representing your wireless connection, once (left click). All surrounding wireless SSID's will be listed only if your wireless adapter is working properly - it must be on in order to receive SSIDs.
Nov 01, 2010 | Belkin Computers & Internet
My wireless router was working then the wireless and security light are now off. Wireless internet is not working
Someone in your neighborhood got into your router and turn it off, so they can get and use your internet connection. I would reset the router by the reset button, and right away put a password on it, and then use mac address filtering on the router. This will only allow your computer access to the internet.
Aug 09, 2009 | Belkin N1 Vision Wireless Router
283 people viewed this tip
David Payne
David Payne
