Tip & How-To about Computers & Internet
How to use a paper clip to open CD or DVD door
I have answered many questions about CD and DVD drives. One of the most common problems is "My CD door doesn't open"
This can be caused by several things but I am going to explain how to open the door manually.
To do this requires a small Paperclip. Straighten the paperclip. Find the small hole in the CD or DVD door. Gemtly insert the paperclip and push on the button inside. If the drive does not have a mechanical problem the door will open.
Computers & Internet Logo
dvd door doesn't open
if there is a small hole on the panel of your dvd drive push a straightened paper clip inside until you feel it press down this will open up the drive
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrative tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
select properties general troubleshoot, select driver click to reinstall drivers click update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
hope this helps
Sep 24, 2012 | Computers & Internet
my dvd reader is not working properly i.e., not opening at all
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Apr 03, 2012 | Computers & Internet
i emachine dvd rom/burner won't open how can i open it? but before it really do not play any dvd and then now it wont open.
If the door on your CD/DVD drive will not open when you push the eject button (on the front of the drive), Click on Start, My Computer, and Right Click on your CD/DVD drive. Then Click on Eject. If the door still refuses to open, you can insert a paper clip into the small hole on the faceplate of the drive and push it in until the door opens. If the door continues to refuse to open in the normal manner, you will have to replace the drive,
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
Apr 05, 2011 | E-Machines emachines (emachinees) CD-ROM...
I want to know how to open the DVD door
Best regards,
Yavacotech
Jan 31, 2011 | Computers & Internet
i have inserted a disc, the laptop doesn't recognise this and I have no way of ejecting it
Sorry you are having trouble. I have answered many questions about CD and DVD drives. One of the most common problems is "My CD door doesn't open"
Apr 07, 2010 | Dell Studio 1737 Laptop
299 people viewed this tip
David Payne
David Payne
