Tip & How-To about Computers & Internet
There is no windows 7 driver listed for my HP printer, what printer driver do I use?
In most cases were a specific driver is not available, the HP PCL 6 Universal driver will work, you can download it here:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=473039&taskId=135&prodTypeId=18972&prodSeriesId=473038&lang=en&cc=us&submit=Go%20%C2%BB
Computers & Internet Logo
keep getting a pcl error message on the display screen
Most commonly, LaserJet printers are accessed over a network. To workaround the issue, you may try to connect your PC directly to the printer using an IEEE-1284 compliant cable.
or update your driver
The PCL XL error may occur if one or more of the required driver files are missing from your computer or are outdated. In this case, you may visit the HP Website for the latest driver updates, download them, and update the existing driver files.
If the problems with the PCL 6 driver continue to occur, remove it from your system. After removing, install the PCL5 printer driver that is shipped with your HP LaserJet Family Printer. If this driver is not available, use the latest preinstalled driver that is available on your Windows computer.
hope this helps
Feb 01, 2011 | Dell 5100cn Laser Printer
My hp color laserjet cp2025 has the pcl xl error subsystem: Kernel error: Illelgaloperatorsequence operator beginpage position: 14 What can I do to fix this?
A Hewlett-Packard LaserJet printing language, PCL 6 is optimized for printing from graphical user interfaces (GUIs) like Microsoft Windows.
The Enhanced PCL XL, or PCL 6, driver that is included with the HP LaserJet printers provides enhanced WYSIWYG and enhanced performance with application support over the Standard (PCL5e) driver. PCL XL is a new page description language by HP, that is part of PCL 6 and is closer to GDI, which many applications use. Less translation takes place by the driver, which means increased WYSIWYG capabilities, and better performance with applications that support escapes implemented by the Enhanced driver.
While printing using the PCL 6 driver it is possible to encounter a PCL XL error. This error will print out at the LaserJet device, and will look like something similar to the following:
PCL XL error
Subsystem: KERNEL
Error: IllegalOperatorSequence
Operator: EndSession
Position: 15
These type of errors can be PCL interpreter errors, firmware related, tied to communication, driver, driver dependency, and application specific. Additional troubleshooting will be required to further isolate to root cause.
Troubleshooting:
I. Verify printer functionality
To verify printer functionality, perform the following:
1.Power the printer Off.
2.Disconnect the parallel, USB, or network cable.
3.Power the printer On.
4.Once the printer display reports Ready, verify device functionality by printing a Configuration Page from the device.
Note: should the internal printer test not print as expected, and/or a PCL XL error occur, you have then isolated the issue to the printer device, and any network connectivity or driver / application troubleshooting can be ruled out.
II. Verify communication w/ the device
To verify communication with the device, perform the following:
2.Reconnect any communication device cable previously removed
4.Once the printer display reports Ready, perform the following:
a.From the client machine or print server that had previously encountered the PCL XL error open the Printers and Faxes folder.
b.Right click the PCL 6 driver in question and select Properties.
c.From the General Tab select Print Test Page
d.Verify the driver test page successfully printed
Should the test page successfully print, continue with the next troubleshooting section entitled Isolate user, application and/or file.
Should the PCL XL error manifest itself as a result of the driver test page, perform the following:
1.At the print server, or client machine, open the Printers and Faxes folder
2.Click on Add Printer
3.Go through the Window’s driver install process installing the appropriate PCL 6 driver for the device in question, with the following characteristics: printing directly to the device (IP_Address, USB, Parallel, etc), creating a new print queue, selecting to Replace Existing Driver.
4.If the issue persists see section entitled: Microsoft Unidrv driver dependencies.
Note: If using an HP LaserJet PCL 6 device specific driver (discrete), try installing the latest HP Universal Print Driver PCL 6. Available at the hp.com website under support & drivers. Select product cb534a and also select your operating system, download a universal print driver Post Script would be the best selection.
You can also adjust a few settings under printing preferences:
under the advanced tab:
Raster compression:
Set it to max
III. Isolate user, application and/or file
If in fact the printers internal test pages and driver test page have printed successfully, further fault isolation must be performed to correlate the PCL XL error with a specific user, application, and or file. This information is most often easily gathered by speaking with the customer, investigating which user is printing when the PCL XL error manifests itself. Once the user is identified, the application the client was printing from can be isolated, and quite possibly the application file itself.
If an application file consistently causes a PCL XL error when sent to the device, it could be a problem only with the file.
IV. Microsoft Unidrv driver dependencies
The issue was identified to be related to Microsoft unicore files: unidrv.dll, unires.dll, and unidrvui.dll, that were not compatible with the available PCL 6 drivers at that time. Microsoft has developed a hotfix to address the symptomatic PCL XL errors – the Microsoft Hotfix can be reviewed here:
Microsoft Windows 2003 and XP: http://support.microsoft.com/kb/948046/en-us
Microsoft Windows 2008 and Vista: http://support.microsoft.com/kb/948349/en-us
Microsoft Windows 2000: NA
HP LaserJet – PCL XL Error
If anything else let me know,
Al
eliteprintersolutions@gmail.com
May 27, 2010 | HP Laserjet Cp2025n Printer
my hp laserjet 2300 keeps printing an error message. It began after I installed another all in one printer. the message is pcl xl error subsystem: kernael error: illegal operator sequence operator: 0x1b postion: 6
Try updating the printers firmware.
You can download firmware here http://bit.ly/13kZ7i
If the problem remains, try replacing the driver with a PostScript-driver. That should help you out.
Jul 29, 2009 | HP LaserJet 2300 Printer
HP Colorlaser CP2025dn PCL XL error Subsystem: KERNEL Error: IllegalOperatorSequence Operator: BeginPage Position: 14 Printer worked fine until I bought a new computer. Installed fine. Communicates through the network fine. Prints test pages fine but nothing else. No matter which applicatoin I print from I get the above error message. Help?
This seems like a driver issue to me. Are you using the Universal, PCL5 or 6, or PS driver?
If using PCL and are getting this error, try the Universal HP driver from the website. Likewise, if you are using the universal, try the PCL6 device specific driver.
If this fails, let me know and I can assist further
Jun 19, 2009 | HP LaserJet P2015 Printer
printer sends error message HP p2015
As mentioned above, install the universal PCL 5 drivers from HP website. This will fix the error.
Feb 23, 2009 | HP LaserJet P2015 Printer
118 people viewed this tip
David Payne
David Payne
