Tip & How-To about Video Game Consoles & Games
Fix red ring of death on xbox 360
Place a warm towel over xbox for 34 hours
Video Game Consoles & Games Logo
Red Rim of Death when I switch on my XBOX360! It's no longer covered by warranty! Please help
Log into the xbox.com site and register your xbox for a replacement, after entering your serial number on your xbox you can check if the xbox is really out of warrenty, because of the regular accurance of Red Rings of Death Microsoft has extended warrenty on xbox's that fail because of this
if your xbox is even out of the RROD extended warrenty
the only things you can do is buy a new one or do the towel trick
please check your extended warrenty before attempting the towel trick as it will void your warrenty
the towel trick overheats your motherboard so the thermal paste melts back onto the motherboard, please note this is a completely temporary trick to get your xbox working again
to do the towel trick, unplug everything from your xbox (hdd, Video cables) just have the power cable plugged in, wrap your xbox in 3 or 4 towels and turn it on, either by pushing through the towels or by using your controller, leave the xbox on for 5-10 mins
unwrap your xbox and turn it off
leave the xbox off with everything unplugged for 2-3 hours if not longer (the longer the better, you want to make sure your xbox has completely cooled down) then after it cooling down completely (remember, 2-3 hours minimum) turn your xbox on and it should work, it may experience a fault or two, but a couple of resets generally fixes this, remember this is temporary, might get another month or so out of your xbox
Mar 21, 2011 | Microsoft Xbox 360 Console
xbox will not read disc, keeps saying open tray
i know this may sound stupid but .... i want u to go get a warm damp towel not wet just damp. then wrap your xbox 360 into the towel. (if it has a harddrive then take the harddrive off before doing this ) then wait for the towel to dry out this should work
Jan 04, 2011 | Microsoft Xbox 360 Console
Have all in one 2500. "Cartridges not compatible" error. I have 34 (18C0034) and 35 (18C00035). Are those the wrong cartridges? Thanks Terry
Hi. The 34(18C0034) and the 35(18C00035) are compatible with your printer. The printer may not be recognizing the cartridges properly. Make sure the protective blue sticker on the nozzles are already removed. If you have done so but problem still persitent, try cleaning the nozzles of the cartridges. To clean, place a damp and a dry paper towel on the table. Grab one cartridge and place it on damp towel first with the nozzle facing down like how you are placing it in the printer. Draw about 2-3 lines. Then do the same thing on the dry towel. Do the same sequence with the other cartridge. Place one cartridge only in the printer then close it without the other cartridge. Check for any error. If there is, replace that cartridge. If no error, proceed inserting the other cartridge. If there is an error, replace that cartridge. Hope this helps.
Mar 16, 2010 | Lexmark X2500 All-In-One Printer
E74 on my xbox with one red light
your scaler chip on the xbox has gone out. i would recommend sending it in for repair, or you can just do the towel trick, leaving it on for a hour or so with a towel rapped around it and see if that works. i really would not do that and recommend sending it in, but it's not my xbox. your choice.
Dec 11, 2009 | Microsoft Xbox Console
XBOX WONT READ DISK IT JUST KEEPS SAYING OPEN TRAY
try towel fix for half the recommended time 20 mins so half is 10 mins
Aug 20, 2009 | Microsoft Xbox 360 Console
379 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
