Tip & How-To about Cell Phones
Increase iPad, iPhone, iPod battery backup !
  • Minimize use of location services: To disable location services, go to Settings > General > Location Services or use location services only when needed.
  • Turn off push notifications: To disable push notifications, go to Settings > Notifications and set Notifications to Off. Note that this does not prevent new data from being received when the application is opened. Also, the Notifications setting will not be visible if you do not have any applications installed that support push notifications.
  • Fetch new data less frequently: To fetch new data manually, from the Home screen choose Settings > Mail, Contacts, Calendars > Fetch New Data and tap Manually. To increase the fetch interval, go to Settings > Mail, Contacts, Calendars > Fetch New Data and tap Hourly. Note that this is a global setting and applies to all applications that do not support push services.
  • Turn off push mail: Go to Settings > Mail, Contacts, Calendars > Fetch New Data and set Push to Off. Messages sent to your push email accounts will now be received on your phone based on the global Fetch setting rather than as they arrive. If the global Fetch setting is set to Manually, you will not be able to locate your iPhone using the MobileMe Find My iPhone feature.
  • Auto-check fewer email accounts: This can be accomplished by turning off an email account or by deleting it. To turn off an account, go to Settings > Mail, Contacts, Calendars, choose an email account, and set Account to Off. To remove an account, go to Settings > Mail, Contacts, Calendars, choose an email account, and tap Delete Account.
  • Minimize use of third-party applications: Excessive use of applications such as games that prevent the screen from dimming or shutting off or applications that use location services can reduce battery life.
  • Turn off Wi-Fi: Go to Settings > Wi-Fi and set Wi-Fi to Off. Note that if you frequently use your iPhone to browse the web, battery life may be improved by using Wi-Fi instead of cellular data networks.
  • Turn off Bluetooth: Go to Settings > General > Bluetooth and set Bluetooth to Off.
  • Use Airplane Mode in low- or no-coverage areas: Because your iPhone always tries to maintain a connection with the cellular network, it may use more power in low- or no-coverage areas. Turning on Airplane Mode can increase battery life in these situations; however, you will be unable to make or receive calls. To turn on Airplane Mode, go to Settings and set Airplane Mode to On.
  • Adjust brightness: Dimming the screen is another way to extend battery life. Go to Settings > Brightness and drag the slider to the left to lower the default screen brightness. In addition, turning on Auto-Brightness allows the screen to adjust its brightness based on current lighting conditions. Go to Settings > Brightness and set Auto-Brightness to On.
  • Turn off EQ: To turn EQ off, go to Settings > iPod > EQ and tap Off. Note that if you’ve added EQ to songs directly in iTunes, you’ll need to set EQ on iPhone to Flat in order to have the same effect as Off because iPhone keeps your iTunes settings intact. Go to Settings > iPod > EQ and tap Flat.
  • Turn off 3G: To disable 3G, from the Home screen choose Settings > General > Network and set Enable 3G to Off. You will still be able to make and receive calls and access cellular data networks via EDGE or GPRS where available.
  • Avoid Using Winter-board theme
Cell Phones Logo
My iPhone 6 uses a lot of data
Start by looking at usage in your settings...
Settings > Mobile Data ... this will show you every enabled app and how much data it's used (incl. system services [at bottom])
Sometimes Location Services transfer a lot of data. Check here for most recent usage:
Settings > Privacy > Location Services
You can also check which apps are using the most battery:
Settings > Battery
And which apps are saving the most data:
Settings > General > Storage
Dec 09, 2016 | Cell Phones
Delete a shared location through text messages on iPhone 6
Here's how to disable Location Services after you use the Share My Location feature:
1. Open your Settings app
2. Tap Privacy
3. Tap the Location Services panel
4. Tap the Location Services slider so it is White / OFF
You can stop sharing your location in iMessage as Daniel said.
Sep 09, 2015 | Apple iPhone 6
What is draining my battery in my iphone 5
What version are you on? Please ensure to check what all apps are using location services under settings privacy location service... Disable location service for all unwanted apps. Also under location service there are system services which use location services and drain your battery. Switch it off for most of them except find my iphone and time zone. This should help big time.
Dec 29, 2014 | Cell Phones
How do I change my current location?
If you're wanting an app to update your current location, make sure when you load the maps application that it is loading your actual current location.
Also, check your settings under Settings->General->Location Services and make sure you have location services turned on.
Mar 08, 2011 | Apple iPhone 4 Black Smartphone
179 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
