Tip & How-To about Heating & Cooling
Keeping your A/C running at top performance
As the weather is getting warmer, the need for cooling comes into play.
Follow these basic steps.
1. Change the filter
2.Clean the "Condenser" (Outside Unit on Central, back on Window Unit)
use a "foaming" spray then rinse with a garden hose.
3. Lube motor
Heating & Cooling Logo
Fridge isnt cooling
There are numerous reasons for a refrigerator to discharge only cool air; weak compressor, low refrigerant, etc.
However, there are two very common reasons for refrigerators the age of yours to under cool. 1. Dirty condenser coils. Check the condenser and ensure that it is clean. This should improve performance. If that does not solve your problem then 2. Evaporator is freezing up. This can be caused by a faulty defrost timer, a failed defrost element, or a faulty defrost thermostat.
Aug 24, 2014 | Frigidaire Kennmore Water Filter 2 Pack
side by side dosen't stay cool enough
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 19, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
refrigerator and freezer are not cooling. already clean condenser coils. evaporator coils are not frozen. fans are working. compressor running.
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator Repair
heatman101
Jun 08, 2010 | Whirlpool GS6NBEXR Side by Side...
My laptop used to play dvds but no longer works, cd's still work fine but dvds wont play, but still come up in computer.
02bc6b7.jpg Do follow steps,
1) change your DVD disk :- if it's work, don't worry about the driver.
2) go to Device Manager & check the DVD/CD ROM driver's property, check weather it has been disabled.
3) change your OS or Upgrade current OS
4) if above steps are not worked, then you have to bring your laptop to a service provider...
if you are in warranty period don't remove any parts of it, they will replaced a another DVD driver
Feb 11, 2010 | Toshiba Satellite Pro L300 Notebook
not cooling predictably
Possible causes are dirty filters, dirty condenser coil, dirty evaporator coil, or low referigerant charge. Any one of the conditions will affect heat transfer.
Check the filters in your indoor unit, If they seem to be clean and replaced on a regular basis, your evaporator coil is probably in good shape. Unfortunatley on some Weather King models even checking the evaporator coil is not possible due to the extensive amount of referigerent lines that block access to the coil without some major work including evacuating the refrigerant.
The most likely cause is a dirty outdoor condenser coil. On weather king models you will have to remove the casing that surrounds the coil because is is built in such a way that the condenser coil cannot be properly cleaned with the casing in place. Once it is removed make sure breaker is switched off and clean the coil with a water hose.
If your outdoor coil is not dirty then it is a refrigerent problem.
Jun 10, 2008 | Weather King 10AJA3601AH Air Conditioner
141 people viewed this tip
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
