Tip & How-To about Dishwashers
"Generic" Schematic of a DishWasher
Just to familiarize yourself.
Dishwashers Logo
how do i fix the high beams on a 1992 chevy pickup
I would check the bulbs and if you get no joy try the fuses afterwards. If it is neither of these is it due to your stalk control,you may have to pull it all the way back towards yourself to activate them or push it forwards, (sorry I am not familiar with this model, I am assuming here, that you are not very familiar with the car also.)
Mar 23, 2015 | 1992-1994 Chevy C/K 1500 Molded Dash Cover...
Can I replace the pilot light on a Vulcan Freeloader 260 gas HWS?
Hello...how old is the unit? Today it is very common for gas appliances to have electric igniters instead of a pilot light. Unless you are familiar with gas controll/regulator valves I would not recommend trying this yourself. I believe it is more likely a faulty or dirty thermo-couple. Again , unless you are familiar with the opperation of gas supplies ,controls ,etc. DO NOT ATTEMP to do this yourself!!! Gas is very dangerous for the less than well informed! Call a service pro or speak to and ask for the assistance of a knowledgable friend.
Feb 14, 2011 | Water Heaters
21PT4475 where is the fuse located?
Usually with these types of TVs the fuse is located on a circuit board inside, often right next to where the power cord enters through the plastic case of the tv. If you are not familiar with electronics, I would not recommend replacing the fuse yourself, for safety reasons. See if you can get a professional to do it for you, or at least a friend that is familiar with electronic devices. Good luck! Der Strom
Sep 27, 2010 | Philips 21PT4475 TV
immobiliser fault
You sound like you are familiar with your hardware. Did you install this system yourself? If so you should know how to re-route back to pre install on the circuit that has been rendered unusable. If not you need someone familiar with that system or an installer with the schematics of it or a new controller, whichever iis available. good luck!
Jun 20, 2009 | Car Audio & Video
we cannot get our watch set to Mountain time. I cannot get the
If you are not familiar with battery replacement and do not want to do it yourself, then nearest jeweller or watchmaker shop will do it for you.
If you wanna try it yourself, ask me questions and I'll guide you how to.
Jan 19, 2009 | La Crosse K2-100 Wrist Watch
240 people viewed this tip
Top Dishwashers Experts
Owen Barnes
