Tip & How-To about Plumbing
Weak flushing, always leaking water saver toilets
I have a new product that I would like you to help me market. My patent is an over-flow tube for “water-saver” toilets. After being tormented by toilets that leaked and needed at least 2 flushes, I finally came up with an easy fix without taking off the water tank. It’s called NuFlush. I now have it on my website (NuFlush.com) and also on eBay. My house is only 5 years old and all of my over-flow tubes in the water-saver toilets were only 5.25 inches long. I did not have enough water height in my tank to seat the flapper valve, properly, and our water bills were really high. Please look at my web site and see if you think I am on to something. I think that only someone like your self could market this extension tube. I have built 50 thousand of them, locally, and have started selling them in ACE Hardware stores for $6.00. There are 13 sizes of extension-tubes that range from 1.010 inches to 1.3 inches. I would like to make a deal with you.
Thank you. Ron Drake
Plumbing Logo
the toilet tank takes a long time to fill up
if the water keeps flowing then try replacing the flapper if it still flows then the fill tube gasket or tank to bowl gasket need to be replaced.
Mar 23, 2013 | Home
Our single piece Kohler toilet does not flush clean. It appears to not be using enough water quick enough to give a clean flush. The tank level is just above the white line on the over flow pipe level so there is enough water in the tank. If water is added to the flush from a separate container the flush will be clean. What could be done to improve the flush?fblechen
The flapper on these toilets is a water saver. The water saver flappers can be replaced with a standard flapper and I have found this will help considerably. The flapper is located in the tank at the center bottom. It is the part that flaps up and down when you pull the lever.
May 09, 2011 | Kohler - Toilet - One-piece - San Raphael...
Water level and fill valve
My patent is an over-flow tube for “water-saver” toilets. After being tormented by toilets that leaked and needed at least 2 flushes, I finally came up with an easy fix without taking off the water tank. It’s called NuFlush. I now have it on my website (NuFlush.com) and also on eBay. My house is only 5 years old and all of my over-flow tubes in the water-saver toilets were only 5.25 inches long. I did not have enough water height in my tank to seat the flapper valve, properly, and our water bills were really high. Please look at my web site. I have built 50 thousand of them, locally, and have started selling them in ACE Hardware stores for $6.00 here in Denver. There are 13 sizes of extension-tubes that range from 1.010 inches to 1.3 inches.
Apr 03, 2010 | Toto Aquia II Dual Flush Toilet
Flushing problem with American Standard toilet model 2474
American Standard 2474016.222 also had the same problem mine had two discs apparently on efrom factory perhaps and one from the floating disc that must have fallen off I used a screw to get them out adn drained as much water as possible then went back and forth adding water a little at a time and then using a tolwel to sponge the water out (no shop vac around) After findign one I then found the other. This post saved me sooo much money adn I have dealt with the intermittant problem for years in this spare bathroom THANK YOU SO MUCH
Jun 20, 2009 | Cadet Manufacturing American Standard...
toilet doen't stop flushing
Sounds like the flapper is stuck in the open position.
They sometimes get hung on the flush tube or the chain hanging from the handle.
Is the water level overflowing the tube?
If so, try adjusting the level down, you may need a new fill valve if that doesnt work.
Nov 18, 2008 | Eljer Aqua-Saver 12" Two-Piece...
476 people viewed this tip
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
