Tip & How-To about Office Equipment & Supplies
Minimizing Paper Jamming in any printer
When using any laser printer, monochrome or color machine, be sure to fan the paper before inserting into the paper cassette tray. The technique is simple. Holding a stack of paper in your hands, each hand on the short edge, flex the paper to create an arc in the stack. Then pinch down on the ends of the paper and straighten the arc out. You'll produce a bulge in the middle of the stack which creates an air space between every sheet in the stack. Now the paper will not cling and paper jams will not occur.
The 2nd tip is to note which "direction" the paper is cut because feeding the paper in one side first may provide better traction than if you were to feed the other end in first. Paper has a grain and its lays down in one or the other direction.
How to correct a Paper Jam message, when there is no paper in unit(printer)
First up, put paper in it. A failed pick up also registers as a paper jam. Run a test page and find out WHERE the paper feed stops. If the paper does not feed - Clean the primary pick up roller at the Front (usually) that takes paper from the cassette. Please not some of the larger machines have the pick up roller inconveniently placed at the back of the tray cavity
Mar 15, 2016 | Brother International Brother MFC-8910DW...
why does it say add paper in cassette 1 but cassette is full
sorry man we had the same problem theres a black tab on the back of the tray that pushes the paper back so it dosnt go over the back remove it or buy the mod kit for it we simple removed it
Jul 29, 2014 | Kyocera Ecosys FS-2100DN Laser Printer -...
oki error 449
Paper can not be fed
because the cassette of the
Tray 1 or the duplex unit is
extracted.
Install the cassette of the
Tray1 and the duplex unit.
Apr 04, 2014 | Oki Electric Industry OKI B410dn Digital...
we have hl-2170 monochrome laser printer need help for paper jam
If you are having constant jamming issues, the first thing I would check is the paper guides on the cassette. Also make sure there is no paper under the toner cartridge/ drum and in the rear door of the printer.
Oct 04, 2010 | Brother HL-2170W Mono Laser Printer
207 people viewed this tip
k24674
jasbo
jasbo
