Tip & How-To about Computers & Internet
Laptop Power Drain
This troubleshooting will help resolved minor issues like:
1. No LCD display but unit is actually powered ON
2. Laptop battery not charging
3. Keyboard not responding
4. windows no boot issue
*** here's the Tip: tak out the battery and unplugged the power adapater. press and hold the power button for 30 secs then release after 30secs. put the battery/adapter back in. issue above should be resolved. elese fails, contact your computer's manufacturer.
Computers & Internet Logo
sony laptop 9a3n keyboard not working
have you tried troubleshooting following steps , that may help resolve minor issues,like
here is answer to these all : take out the battery and unplugged the power adapter. press and hold the power button for 30 secs then release after 30secs. put the battery/adapter back in. issue above should be resolved.
100%
have a good time do feedback.!
Apr 04, 2011 | Computers & Internet
it doesn't work
ufacturer
Mar 14, 2011 | Computers & Internet
KEYBOARD NOT FULLY WORKING SOME KEYS ARE WORKING FULLY SOME ARE GIVING DIFFERENT WORD I.E. PRESSING S SHOWING X
specify your complete problem what do you mean by my acer laptop is clicking ....
have you problem with your laptop power or OS failure??
check for warranty ..sometimes this happens cause of the voltage problem in your arrea??? check your charger for this
my second openion is
board is X3100 rite .. now check the RAM is it inserted properly , then check for the processor .. unplug it from frame and then insert again check if its not burned .. the chip on its upper level will be shinning and new if it isn't , if it is dark and burn-y type then your processor is out , there is always a power bulb in mother board,,, if it is on when you turn the laptop on then your main board is OK . and if its not then out of work .. sorry for that i am a professional at boards but sometime if you don't see a thing for your self ,things don't work,,,, it is this way ,no matter how much i try if you don't explain the things right to me i wont be able to figure it out . more over have you tried to plug it by VGA cable to a monitor or LCD..
about your issue first of all i wonder that Was the adapter you bought directly from Lenovo? I just know that dell builds in a chip to detect the adapter, some other adapter might work but it will burn down the board after quite some time . may be your another lap top didnt spend much time on that adapter ,
secondly
here is answer to these all : take out the battery and unplugged the power adapter. press and hold the power button for 30 secs then release after 30secs. put the battery/adapter back in. issue above should be resolved. if fails, contact your computer's manufacturer thats the least i want to say , which is the first post i am not willing to say so for you i wish i could have helped.???
my second openion to you is I would say your laptop lcd and other parts are fine it is a mother board you require.
If you browse ebay there are lots to choose from at different prices. It is a straightforward job to replace .:)
Oct 27, 2010 | Lenovo 3000 N200 Intel Pentium Dual Core...
laptop wont turn on
Below you will find my recommendations for troubleshooting this issue.
1. Remove the battery.
2. Confirm that the AC adapter has power.
3. Remove all the customer removable units (CRU) except a single ram module.
Here CRUs to be remove:
* Optical drive
* Primary Battery
* PCMCIA cards
You will only removed the above peripherals if Dell will allow it.
7. Connect the AC adapter directly to the system.
6. Attempt to power on the system using only the AC adapter.
7. If the system does not POST, connect an external monitor and check for POST. This will let you know if there is a problem with the LCD.
I hope this helps resolve the issue.
Jun 07, 2009 | Dell Inspiron 6000 Notebook
i have a tecra S1 toshiba laptop, when i ON the laptop, the power LED goes ON, the harddisk seems to be operating, but there is not any video on the screen, could it be the mother board?
In order to resolve the issue follow the steps below:
1. Turn off the laptop
2.Remove the battery
3.Remove the power adapter
4.Press and hold the power button on laptop for 1 minute in order to remove static charge.
5.Relese the power button after 1 minute and reinsert the battery and power adapter.
6.Turn the laptop on.
This should solve your problem. If the issue persists follow the steps below:
Turn off the laptop
1. Remove the Hard disk
2. Remove the memory RAM.
3.Wait for 2-3 minutes
4.Reinsert the hard disk and RAM.
5.Turn the laptop ON.
This shpuld resolve the issue. Is the issue persists than it is a clearly indication of mother board malfunction and even could be with display.
Thank you.
Nov 29, 2008 | Computers & Internet
1,975 people viewed this tip
David Payne
David Payne
