Tip & How-To about Cell Phones
Mobile charger
In some mobiles, the charger unit does not works properly,but ur battery as well as charger'll be fine......
In such cases dont buy new charger or battery instead just buy "multi-charger".. In that u can charge any kind of battery... Nw ur problem may solved..
Cell Phones Logo
screen is black all the time, can't turn phone on or off
1) Is your charger / adapter working OK ?
Most of the time, an adatper or charger contains a red or green LED, showing it's active, when inserted in the wall-outlet (110 / 240 V AC). In some cases, this LED will emit light, only when the mobile phone is connected.
If this doesn't happen, you might consider buying a new(er) charger for your mobile phone.
2) Is battery charged ?
No further discussion / c;arification needed.
3) Does phone contain an old(er) battery ?
If the mobile phone is used for a longer time or used intensely, the battery might be "worn out". A battery is able to be charged, but will show it's limits, because of it's maximum usage. With this I mean, they can be charged a maximum amount of times. If you even use a quick-charger, the battery may suffer more, resulting in a less longer lifetime. In such case you can replace your battery, by simply ordering / buying a new battery for your mobile phone.
Sep 03, 2013 | Motorola Mobility RAZR V3
won't open,not charging
DEAR SIR,
THIS IS NOT THE PROBLEM CAUSED BY PHONE SOFTWARE OR SOME THING LIKE THAT....
THE PROBLEM IES WITH THE BATTERY AND PLZ ALWAYS USE THE CHARGER SPECIFIED FOR YOUR PHONE AND PLZ DO NOT USE CHARGERS OF OTHER NOKIA MOBILES....BECAUSE IN NOKIA CHARGER PIN ARE SAME,BUT BATTERY MODELS ARE DIFFERENT...........UR BATTERY WILL GET CHARGED BUT THE LIFE LL BE LOWERED.......
THE BATTERY HAS DAMAGED IN YOUR PHONE AND THE SOLUTION IS TO CHANGE UR MOBILE BATTERY.................
TAKE CARE..THANK YOU
Oct 03, 2010 | Nokia 5800 XpressMusic Smartphone
Mobile is getting heated when charging with a duplicate charger.? Is it the problem with the charger or mobile?
it is the problem with the charger...in duplicate chargers, ratings and standards are not followed properly for example if ur mobile battery needs some 10A and 7V(only for example)duplicate charger may give less or more the required ratings...this ll end up in heating ur mobile....
it is always recommended to use branded charger...
Apr 05, 2010 | LG KU990 Viewty
TRY TO CHARGE UR PHONE BY SWITCH OFF IT IF ITS NUTS SOLVE THE PROBLEM THAN DONT GO FOR ANY OTHER CHARGER AND HIGH VOLTAGE IT CAN DAMAGE TO UR PHONE SHOW UR MOBILE ANY NEAR MOBILE REPAIRING SHOP
Jul 15, 2008 | Nokia 6630 Handheld
153 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
