Tip & How-To about Computers & Internet
Fix Blackberry Smart Phone - Diagnose Keyboard GPS Audio Trackball Bluetooth
The Blackberry has an inbuilt feature which allows you to check the operation of its hardware components. This generates a self report and diagnoses on the state of operation of these components.
This is particularly useful if you are having problems with the
- Bluetooth,
- GPS,
- Trackball,
- Keyboard,
- Headset or Handset audio,
- Other hardware components.
Note: You must be running OS version 4.5 or higher for this to work on your unit.
1. First go to Options.
2. Select Status.
3. Type in the word 'Test'.
'4. Select the Menu button.
5. Select Start.
6. Place a check on the category you want
7. Select Run. Your handset will now perform self-diagnostics and produce a report.
To go back view a test report.
1 Go to the Device Self Test Application screen.
2. Select the report you want.
3. Select Menu.
4. Select View.
Please leave a vote for the information if you found it helpful. Thanks.
Computers & Internet Logo
IJUST WANT TO VIEW MY EMAILS AS THEY APPAER
Windows 7 Offline Privacy Statement for the Microsoft Error Reporting Service
For the most up-to-date privacy information, see the online Windows 7 Privacy Statement at:
http://go.microsoft.com/fwlink/?LinkId=104288
WHAT THIS FEATURE DOES
The Microsoft Error Reporting Service helps Microsoft and Microsoft partners diagnose problems in the software you use and provide solutions. Not all problems have solutions, but when solutions are available, they are offered as steps to solve a problem you've reported or as updates to install. To help prevent problems and make software more reliable, some solutions are also included in service packs and future versions of the software.
The Microsoft Error Reporting Service also provides Setup Repair, an error reporting service that may run during Windows setup if a problem occurs.
INFORMATION COLLECTED, PROCESSED, OR TRANSMITTED
Many Microsoft software programs, including Windows 7, are designed to work with the reporting service. If a problem occurs in one of these software programs, you might be asked if you want to report it. If you host virtual machines using a Windows operating system, reports generated by the Windows operating system for the Microsoft Error Reporting Service might include information about virtual machines.
The reporting service collects information that is useful for diagnosing and solving the problem that has occurred, such as:
* Where the problem happened in the software or hardware
* The type or severity of the problem
* Files that help describe the problem
* Basic software and hardware information
* Possible software performance and compatibility problems
These reports might unintentionally contain personal information. For example, a report that contains a snapshot of computer memory might include your name, part of a document you were working on, or data that you recently submitted to a website. If a report is likely to contain this type of information, Windows will ask if you want to send this information, even if you have enabled automatic reporting through the "Recommended settings" option in setup, or Control Panel. This gives you the opportunity to review the report before sending it to Microsoft. Reports including files and data might be stored on your computer until you have an opportunity to review and send them, or after they have been sent.
If an error report contains personal information, Microsoft does not use the information to identify you or contact you. In addition, if you enable automatic reporting through the "Recommended settings" option in setup, or in Control Panel, the reporting service will send basic information about where problems occur automatically, but these reports will not have the detail described above.
After you send a report, the reporting service might ask you for more information about the error you experienced. If you choose to provide your phone number or e-mail address in this information, your error report will be personally identifiable. Microsoft might contact you to request additional information to help solve the problem you reported.
The Microsoft Error Reporting Service generates a globally unique identifier (GUID) that is stored on your computer and sent with error reports to uniquely identify your computer. The GUID is a randomly generated number; it does not contain any personal information and is not used to identify you. We use the GUID to distinguish how widespread the feedback we receive is and how to prioritize it. For example, the GUID allows Microsoft to distinguish between one customer experiencing a problem one hundred times and one hundred customers experiencing the same problem once.
USE OF INFORMATION
Microsoft uses information about errors and problems to improve Microsoft products and services as well as third-party software and hardware designed for use with these products and services. Microsoft employees, contractors, vendors, and partners might be provided access to information collected by the reporting services. However, they will use the information only to repair or improve Microsoft products and services and third-party software and hardware designed for use with Microsoft products and services.
Microsoft might share aggregate information about errors and problems. Microsoft uses aggregate information for statistical analysis. Aggregate information does not contain specific information from individual reports, nor does it include any personal or confidential information that might have been collected from a report.
Except as described in this statement, personal information you provide will not be transferred to third parties without your consent. We occasionally hire other companies to provide limited services on our behalf, such as performing statistical analysis. We will only provide those companies the personal information they need to deliver the service, and they are prohibited from using that information for any other purpose.
Microsoft may access or disclose information about you, including the content of your communications, in order to: (a) comply with the law or respond to lawful requests or legal process; (b) protect the rights or property of Microsoft or our customers, including the enforcement of our agreements or policies governing your use of the software; or (c) act on a good faith belief that such access or disclosure is necessary to protect the personal safety of Microsoft employees, customers, or the public.
Information collected by or sent to Microsoft by Windows 7 may be stored and processed in the United States or any other country in which Microsoft or its affiliates, subsidiaries, or service providers maintain facilities. Microsoft abides by the safe harbor framework as set forth by the U.S. Department of Commerce regarding the collection, use, and retention of data from the European Union.
CHOICE AND CONTROL
If you choose the recommended settings during Windows 7 setup, basic information about errors will be sent automatically to Microsoft. If a more detailed error report is required, you will be prompted to review it before it is sent. You can change this setting at any time by going to Action Center in Control Panel.
SECURITY PRACTICES
Microsoft is committed to helping protect the security of your information. We use a variety of security technologies and procedures to help protect your information from unauthorized access, use, or disclosure. For example, we store the information you provide on computer systems with limited access, which are located in controlled facilities.
FOR MORE INFORMATION
If you have questions about this privacy statement, please contact us by submitting your questions online to Privacy Feedback at:
http://go.microsoft.com/?LinkID=9634754
c/o Microsoft Privacy Response Center
Microsoft Corporation
One Microsoft Way
Redmond, Washington 98052 USA
Jul 30, 2013 | Computers & Internet
how to reactivate or reinstall the disk defragmenter?
USE OF INFORMATION
CHOICE AND CONTROL
SECURITY PRACTICES
One Microsoft Way
Jul 30, 2013 | Microsoft Windows 7 Home Premium 64BIT...
How do I print the fax log?
Follow the steps below to print Fax Logs for already received faxes
  1. Press Setup , and then press 2 . This displays the Print Report menu.
  2. Press the Right arrow button to scroll through the following report types:
    • Fax Report Setup: prints the automatic fax reports as described in Generate reports automatically.
    • Last Transaction: prints details of the last fax transaction.
    • Fax Log: prints a log of approximately the last 30 fax transactions.
    • Speed Dial List: prints a list of programmed speed-dial entries.
    • Self-Test Report: prints a report to assist in diagnosing print and alignment problems.
  3. After the desired report is highlighted, press OK .
Also, Click on the link below for more information about Fax settings on your printer
Fax Settings
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Dec 31, 2010 | HP OfficeJet 6210 All-In-One InkJet...
A75 not recognizing all of the memory
How much of the memory is not being recognized out of the total RAM?
Most laptop video cards do not have built-in RAM and part of the main memory is used for video RAM. Depending upon the video chip, it could grab 256Mb or more RAM for video.
If the RAM is equal to the extra RAM module being installed, then the problem could be incompatible RAM module or a faulty memory expansion slot.
Try and use RAM with the same speed and from the same manufacturer.
Oct 25, 2009 | Toshiba Satellite A75-S226 Notebook
113 people viewed this tip
David Payne
David Payne
