Tip & How-To about Apple iPhone 3G
Recover from a Forgotten iPhone or iPod Touch Passcode
If you have forgotten your passcode on your iPhone or iPod Touch, you will need to do a restore in iTunes, but you must first put the phone in "restore mode." However, when you do a forced restore on iphone, you will wipe all content from the iphone, there is no other way around this. To put the phone in restore mode, hold the HOME button while the phone or ipod is off. Then, connect it to the USB cable and continue holding for a LONG time (or as long as it takes until you see a screen with a cable and the itunes logo). Once iTunes responds that it sees a connection in recovery mode, click restore and it will reload the phone/ipod to factory settings, and will be free of the forgotten password.
Apple iPhone 3G Logo
i need to change my password but my 5s isnt allowing me to do so
Go to iphone setting - then passcode or touch id & passcode. now tap on change passcode and then enter your old passcode and then new passcode. And if you forgot your passcode and your ipod iphone disabled and you want to unlock disabled iphone ipad.
here is the detail procedure
First method you can restore your ipod. But this will erase all your data on ipod. So if you have recent backup then go for restoring ipod. For that just connect your ipod to computer- then open itunes. Make sure you have installed latest itune version otherwise update your itunes first. Now open itunes then find your ipod under deivce tab at the top left sidecorner. Click on your ipod icon. Click on summary and then click on restore.
You can also restore your ipod from old backup also. For that open itunesfind your ipod under device menu. Now select your ipod and then right click on your ipod the you will get options for restore from backup.Select restore from backup this will provide list of all your previous backup on that computer itunes. Now select your backup which you want to restore and then click on continue. Once your restoring is completed your ipod will shut down and then again restart your ipod it will take few minutes to start up. And it also asks few information about you. Once you complete all that procedure your ipod is unlocked which was disable or locked due to wrong passcode.
Dec 26, 2016 | Apple iPhone 5S
how do i unlock my iphone 4 when its disabled
Does this copied and pasted advice help you?
iOS: Forgot passcode or device disabled If you set up a passcode on your iPhone, iPad, or iPod touch, and you or someone else then enters the wrong passcode too many times, your device will disable itself temporarily. Learn what to do if you have forgotten your passcode, or if your device displays a message saying it's disabled.If you enter the wrong passcode six times in a row, you'll be locked out and you'll see this message:
  • iPhone is disabled
  • iPad is disabled
  • iPod touch is disabled
If you can't remember your passcode, you'll need to erase your device using iTunes, Find My iPhone, or recovery mode. Then use a backup to put your data and settings back on your device. Here's how. Use iTunes If you have synced your device with iTunes, you can restore your device.
  1. Connect the device to the computer you normally sync with.
  2. Open iTunes. If iTunes asks you to enter the passcode, try another computer that you've synced with. Or try the steps below to use recovery mode.
  3. iTunes will automatically sync your device and create a backup. If it doesn't, sync the device with iTunes.
  4. After the sync is complete, restore your device.
  5. When iOS Setup Assistant asks to set up your device, choose "Restore from iTunes backup."
  6. Select your device in iTunes and choose the most recent backup.
Use Find My iPhone If you enabled Find My iPhone, you can use it to erase your device.
  1. Go to icloud.com/#find to see if you enabled Find My iPhone.
  2. Click All Devices at the top of your browser window.
  3. Select your device and click "Erase [device]" to erase your device and its passcode.
  4. Use the Setup Assistant on your device to restore the most recent backup of your device.
Use restore your device as new or from a backup.
  1. Disconnect all cables from your device.
  2. Turn off your device.
  3. Press and hold the Home button. While holding the Home button, connect your device to iTunes. If your device doesn't turn on automatically, turn it on.
  4. Continue holding the Home button until you see the Connect to iTunes screen.
  5. iTunes will alert you that it has detected a device in recovery mode.
  6. Click OK, then restore the device.
Last Modified: Jul 8, 2014
Aug 04, 2014 | Apple iPhone 4 Black Smartphone
FORGOT PASSWORD
If You Are Locked Out, Have Forgotten Your Passcode, or Just Need to Restore Your Device
If you have forgotten your Restrictions code, then follow the instructions
below but DO NOT restore any previous backup. If you do then you will
simply be restoring the old Restrictions code you have forgotten. This
same warning applies if you need to restore a clean system.
A Complete Guide to Restore or Recover Your iDevice (if You Forget Your Passcode)
If you need to restore your device or ff you cannot remember the passcode, then you will need to restore your device using the computer with which you last synced it. This allows you to reset your passcode and re-sync the data from the device (or restore from a backup). If you restore on a different computer that was never synced with the device, you will be able to unlock the device for use and remove the passcode, but your data will not be present. Refer to Updating and restoring iPhone, iPad and iPod touch software.
Try restoring the iOS device if backing up and erasing all content and settings doesn't resolve the issue. Using iTunes to restore iOS devices is part of standard isolation troubleshooting. Restoring your device will delete all data and content, including songs, videos, contacts, photos, and calendar information, and will restore all settings to their factory condition.
Before restoring your iOS device, Apple recommends that you either sync with iTunes to transfer any purchases you have made, or back up new data (data acquired after your last sync). If you have movie rentals on the device, see iTunes Store movie rental usage rights in the United States before restoring.
Follow these steps to restore your device:
1. Verify that you are using the latest version of iTunes before attempting to update.
2. Connect your device to your computer.
3. Select your iPhone, iPad, or iPod touch when it appears in iTunes under Devices.
4. Select the Summary tab.
5. Select the Restore option.
6. When prompted to back up your settings before restoring, select the
Back Up option. If you have just backed up the device, it is not necessary
to create another.
7. Select the Restore option when iTunes prompts you (as long as you've backed up,
you should not have to worry about restoring your iOS device).
8. When the restore process has completed, the device restarts and displays the Apple
logo while starting up:
After a restore, the iOS device displays the "Connect to iTunes" screen. For updating
to iOS 5 or later, follow the steps in the iOS Setup Assistant. For earlier versions of
iOS, keep your device connected until the "Connect to iTunes" screen goes away or
you see "iPhone is activated."
9. The final step is to restore your device from a previous backup. If you do not have a
backup to restore or have forgotten your restrictions passcode, then restore as New. If you are restoring to fix a forgotten Restrictions Code or as a New device, then skip Step 9 and restore as New.
Feb 13, 2014 | Apple iPod nano 5th Generation
i cant remeber my pascode fro my ipod touch 4
to create another.
Feb 10, 2014 | Apple iPod touch
ipad forgotten password
From the apple support site:
iOS: Forgotten passcode or device disabled after entering wrong passcode When you set up a passcode to secure the use of your iPhone, iPad, or iPod touch and then enter the wrong passcode, you may see a a message saying your device is "disabled". Learn what to do if you have forgotten or can't remember your passcode, or if your device displays a message saying it is disabled.If you enter the wrong passcode six or more times, you'll see a message that says one of the following:
  • iPad is disabled
  1. Connect the device to the computer with which you normally sync and open iTunes.
    Note: If iTunes asks you to enter the passcode, try another computer that you have synced with. Otherwise, go to "If you have never synced your device with iTunes, or you do not have access to a computer" section below.
  2. If the device is still disabled, or if iTunes does not automatically sync your device, sync the device with iTunes.
  3. When the backup and sync is complete, restore your device.
  4. When iOS Setup Assistant asks to set up your device, choose "Restore from iTunes backup".
  5. Select your device in iTunes and choose the most recent backup of your device.
Hope this helps!
http://support.apple.com/kb/ht1212
Feb 05, 2014 | Apple iPhone 3G
963 people viewed this tip
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
