Tip & How-To about Home
How to repair a broken hose on a waterpik oral irrigator
This is the third unit I have had which failed when the hose cracked at the handle. This time I decided to repair it instead of investing another 50 dollars for a new one. I used my trusty Leatherman with the serrated blade, to open the two halves of the handle - along the glue line. I slid the half of the handle down the hose and left it there for later.
Once open I slipped the collar off the tubing and down the hose. I needed it later and this way I knew where it was!! Next I used the blade to shave the old hose stub off the barbed connector being careful not to damage the barbed fitting.
Next I heated the end of the freshly cut-off hose in boiling water and pressed it onto the barbed fitting. Now I slid the locking collar back down the hose and onto the hose at the fitting. After assembling the handle I put a stainless steel worm-drive hose clamp ont the handle and the unit works once again . . . until the next time the hose breaks!!
http://www.misterfixit.com
Home Logo
Hoover Steamvac Agility won't pick up dirty water
Press the handle release kick-button with your foot, extend the handle all of the way back, and take a look at the gap between the base of the unit and the handle/reseviour assembly. You should see several black hoses attached to the base and running up into the handle assembly. One of them (the dirty water return hose) might be cracked. Turns out that might be a common problem with this model. We had the same problem.
Judging by the interference between the vacuum hose and the "dirty water return" hose, there is NO WAY those two hoses can exist together in that housing without causing the dirty water return hose can last for many full bends of the handle. We opted to not repair our unit, but you might be able to do it yourself for the cost of the part and several hours of your time. Otherwise, seek out your certified Hoover repair center for more info.
May 01, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
heater hose was cut and caused to loose all coolant
First what kind of motor do you have 2.5l, 3.1L?
Mar 31, 2009 | 1992 Pontiac Grand Am
cracked hose for Bissell SpotBot
I found a site that carrys them, not sure if they are out because just as I was about to order one I decided to try and fix mine since the crack was right up next to the handle. http://www.svcvacuum.com/bissell/steamer_hose.htm
All I did was unscrew the two screws where the button is for releasing the water on the hand piece. I thin squeezed the clamp together to remove the water hose. Once that was removed I cut the hose and then PRYED out the part of the hose in the hand piece. I then cut the hose down where the crack was. Feed the "water hose" back through the hole in the handle (I heated it with a lighter just a tiny bit to make it soft and worked it through the hole which I just enlarged a slight bit) and with pliers work it back on. Don't forget the clamp. Next just work the outter hose back into the handle but make sure to use a glue or silicone sealer or both.
Even if you get a new hose Im not sure it will come with the handle. To connect the hose to the Machine part just push in that little plastic "dot" and pull out the hose at the same time. Then remove the old hose by the directions above. There is no need to remover the inner clear hose from the machine part, only the handle
Jan 17, 2009 | Bissell SpotBot Robotic Wet/Dry Vacuum
Repairing DVDR985
Thanks for the prompt reply. After discussing the problem with a Philips rep., Philips decided to send me an exchange unit for no charge other than my paying for the shipment.
Mar 05, 2008 | Philips DVDR985 DVD Recorder
3,959 people viewed this tip
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
