Tip & How-To about Office Equipment & Supplies
"The waste ink absorber is almost full" message?
This applies to the CANON PIXMA MP130 and other ink-jets made by Canon/Pixma.
According to the user's manual, "Ink used to clean the print head is absorbed by the waste ink tank. When this message is displayed, the waste ink tank needs to be replaced, or the machine requires maintenance". There is no information about how to replace or empty the waste ink tank.
In any case, you can try the following to clear up the error, but eventually you'll need the waste tank to be emptied or replaced. And as far as I know, you can't find the replacement parts to buy, nor the instructions to empty the waste tank.
Turn on your MP130.
1) After that press: Menu - Scan - Copy - Scan or Menu-Copy-Scan-Copy-Copy in some models, it depends on the date it was produced)
2) Select TEST MODE.
3) Enter NVRAM ACCESS
4) Select SET ABS-M LEVEL TO 0
5) Select OK
6) Keep selecting OK untill you leave the TEST MODE
Then turn it OFF and again ON. Check if the error message is still there.
The following is taken from the Canon website, regarding this specific error:
"Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk."
As I mentioned before, I have not found any way or procedure to empty or replace the waste ink absorber nor the necesary replacement part.
My canon PIXMA iP 4000 does'nt write out the colours, only black.
Use the Canon software to check the ink-levels in the COLOUR cartridge. If empty, replace it.
Use the Canon software to run a few "print-head-cleaning" cycles, to unclog any ink-jets that are not spraying ink onto the paper.
Feb 22, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
Hi. No magenta or cyan printing on my canon pixma 750. used the maintenance cleaning function and head refreshing to no avail. Any ideas,thanks Mark
Sounds like the ink jet cartridges need to be replaced. Cleaning will not solve the problem after the ink is depleted, and if the ink were low, the cleaning process uses up a lot of ink.
Good luck on replacing the ink jet cartridges.
Jul 16, 2010 | Canon PIXMA MP750 All-In-One InkJet...
Canon Pixma ip2000 Inkjet printer wont print black. Replacing cartridge did not fix the problem.
Remove ink cartridges,then print head.
Clean print head with dry cue tips.
Apply strong suction over black print
jets on print head.
Replace print head and cartridges.
It worked for me.
Oct 17, 2009 | Canon PIXMA iP2000 InkJet Printer
Canon pixma mp130
1. Take out black and coloured ink cartridges.
2.Clean golden contacts with a q-tip dipped in alcohol'both on the print head and on the cartridge.
3. Dip the cartridge in a hot water bowl, let all the ink left flow out.
4. Wipe with a paper towel.
5. Let the parts dry out for at least 24 hours
Oct 03, 2009 | Canon PIXMA MP130 All-In-One InkJet...
doesn't print
Open the printer and make sure the cartridges or printer head does not have any packing tape or anything like that covering the ink jets. If that is not it, try reinstalling the printer drivers and printing a test page.
Dec 29, 2007 | Canon PIXMA MP130 All-In-One InkJet...
222 people viewed this tip
k24674
