Tip & How-To about Toshiba Satellite A135-S2276 Notebook
Resetting the bios password for Toshiba Laptop
It working with the Satellite A135
Power unit off. Disconnect AC power. Remove battery. Remove the memory cover screw, memory cover and the memory modules. Peel back the black lebel back from memory module 1, I soldered PAD500 solder pads (to short circuit them), install one memory memory in slot 2 and turned notebook on, it erase the password and boot without asking for one. Then power off desolder PAD500, replace mylar. Replace memory modules. Replace battery. Power up unit, replace memory cover and screw. Whalá!! the password gone, and you can enter to bios setup to set a new password if you want.
Toshiba Satellite A135-S2276 Notebook Logo
I HAVE A TOSHIBA SATELLITE a135- S2246 SERIAL NO: 17203847k I NEED TO GET A PASSWORD BIOS. WHAT DO I NEED TO DO? THANK YOU ANNETTE DURAN
If you forgot bios passord
I have a Satellite A135-S2356 that had the same problem. I tried the solution from PCTServices above and it worked great.
"Power unit off. Disconnect AC power. Remove battery. Remove the memory cover screw, memory cover and the memory modules. Peel back mylar from JOPEN1 solder pad. Short JOPEN1 solder pads for 30 seconds. Replace mylar. Replace memory modules. Replace battery. Power up unit. If all is well, replace memory cover and screw."
Just short the two little solder pads and it worked great!
Jun 25, 2009 | Toshiba Satellite A135-S2246 Notebook
Need a password...
Found these instructions on another website...
Hope this helps
Regards
Aug 18, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba satellite 310 series (china)
Aug 16, 2008 | Toshiba Satellite A135-S2276 Notebook
HAVE A TOSHIBA SATELLITE A135-S4677 NOTEBOOK AND HAVE FORGOTTEN MY HDD1 INNER BIOS PASSWORD & NEED TO RESET IT IF POSSIBLE.
This works only for some models.
Power unit off. Disconnect AC power. Remove battery. Remove the memory cover screw, memory cover and the memory modules. Peel back the mylar. there should be a set of solder pads labeled JOPEN1. Short the JOPEN1 solder pads for 30 seconds. Replace mylar. Replace memory modules. Replace battery. Power up unit. If all is well, replace memory cover and screw. Hope this helps.
Feb 29, 2008 | Computers & Internet
4,267 people viewed this tip
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
