Tip & How-To about Microsoft Windows Vista Ultimate Edition
Speedup your work using shortcut in windows
You can use these shortcuts when using windows.It will speedup your work. Please try them.
• CTRL+C (Copy)
• CTRL+X (Cut)
• CTRL+V (Paste)
• CTRL+Z (Undo)
• DELETE (Delete)
• SHIFT+DELETE (Delete the selected item permanently without placing the item in the Recycle Bin)
I know they all above are general, but you can enjoy the followings:
• CTRL while dragging an item (Copy the selected item)
• CTRL+SHIFT while dragging an item (Create a shortcut to the selected item)
• F2 key (Rename the selected item)
• CTRL+RIGHT ARROW (Move the insertion point to the beginning of the next word)
• CTRL+LEFT ARROW (Move the insertion point to the beginning of the previous word)
• CTRL+DOWN ARROW (Move the insertion point to the beginning of the next paragraph)
• CTRL+UP ARROW (Move the insertion point to the beginning of the previous paragraph)
• CTRL+SHIFT with any of the arrow keys (Highlight a block of text)
• SHIFT with any of the arrow keys (Select more than one item in a window or on the desktop, or select text in a document)
• CTRL+A (Select all)
• F3 key (Search for a file or a folder)
• ALT+ENTER (View the properties for the selected item)
• ALT+F4 (Close the active item, or quit the active program)
• ALT+ENTER (Display the properties of the selected object)
• ALT+SPACEBAR (Open the shortcut menu for the active window)
• CTRL+F4 (Close the active document in programs that enable you to have multiple documents open simultaneously)
• ALT+TAB (Switch between the open items)
• ALT+ESC (Cycle through items in the order that they had been opened)
• F6 key (Cycle through the screen elements in a window or on the desktop)
• F4 key (Display the Address bar list in My Computer or Windows Explorer)
• SHIFT+F10 (Display the shortcut menu for the selected item)
• ALT+SPACEBAR (Display the System menu for the active window)
• CTRL+ESC (Display the Start menu)
• ALT+Underlined letter in a menu name (Display the corresponding menu)
• Underlined letter in a command name on an open menu (Perform the corresponding command)
• F10 key (Activate the menu bar in the active program)
• RIGHT ARROW (Open the next menu to the right, or open a submenu)
• LEFT ARROW (Open the next menu to the left, or close a submenu)
• F5 key (Update the active window)
• BACKSPACE (View the folder one level up in My Computer or Windows Explorer)
• ESC (Cancel the current task)
• SHIFT when you insert a CD-ROM into the CD-ROM drive (Prevent the CD-ROM from automatically playing)
• CTRL+SHIFT+ESC (Open Task Manager)
Microsoft Windows Vista Ultimate Edition Logo
I can not find at the top of my screen the cut copy and paste buttons
What program are you using?
Try these handy keyboard shortcuts:
Cut - press together CTRL (and) X
Copy - press together CTRL (and) C
Paste - press together CTRL (and) V
Feb 28, 2014 | Computers & Internet
The shortcut for copy, cut and paste don't work - how do I set up the ctrl c, ctrl x and ctrl p shortcuts
Hi.
These are keyboard shortcuts only, you can use the the mouse to copy and paste by using the right click button.
Regards.
Feb 03, 2013 | Logitech k200
how do i get cut copy & paste on windows 7
There are standard keyboard options are available for cut, copy and paste operations. These are bydefault enabled in all type of windows based softwares.
Cut - > Ctrl + X
Copy - > Ctrl + C
Paste - > Ctrl + V
Above type of operations are allowed in all type of Windows Versions (95 / 98 / NT / 2000 / 2003 / XP / Vista / 7)
Thanks,
Amar
Oct 07, 2010 | Microsoft Computers & Internet
cut or copy and paste does not work
That is very common problem and there is no one-best-sollution for it since they are tons of possible reasons.
Possible sollutions:
#1 close all programs
#2 switch off->switch ON pc
#3 scan for possible malware using antivirus software
#4 try using keyboard shortcuts crtl+c = copy or ctrl-x = cut
Leave rate if I helped you, thanks!!
Cheers,
Mike
May 09, 2010 | Microsoft Windows Vista Ultimate Edition
I don't know how to cut and paste my story on to my you tube web page
highlight the parts you wish to copy by selecting with left mouse button. Now hold the CTRL key + C key (thats the kb shortcut for copy)
Next, go to your webpage and use CTRL+P (kb shortcut for paste)
Sometimes the mouse function for cut and paste may not work with all sites..
Try this first and let me know..
May 24, 2008 | Computers & Internet
334 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
