Tip & How-To about Cell Phones
How to Put Bluetooth In Pairing Mode
To put your bluetooth in discovery or Pairing Mode - press and hold the middle button for about ten Seconds and when it starts flashing - or stays on a Sold Color ( red or Blue ) depending on the bluetooth. - - that means it is in Pairing mode.
you can than go to your phone and make it look for devices.
hope this helps
Marvin
Cell Phones Logo
I am having trouble getting my 6230i to pick up my bluetooth headset.
you have to put the Bluetooth in pairing Mode and put the Phone in Discovery Mode also.
to put your bluetooth in discovery Mode - press and hold the middle button for about ten Seconds and when it starts flashing - or stays on a Sold Color ( red or Blue ) depending on the bluetooth. - - that means it is in Pairing mode.
hope this helps
thanks
Mar 31, 2010 | Nokia 6230i Cellular Phone
My Jawbone bluetooth wont go into discovery mode.
I believe it needs to be on....then hold in the button for pairing until it is steady red....once it syncs up it will start flashing white until you turn it off.
Oct 22, 2009 | Cell Phones
bluetooth syncing
Usually to solve some pairing problems shut off bluetooth completely(no lights) Push and hold button until bluetooth comes on,flashes then steady light,you may have to hold button for ten seconds or more.Then put phone in pairing mode.
When asked for pass code enter 0000.Phone should show connected to bluetooth device.
Apr 24, 2008 | Jabra BT350 Bluetooth Headset Headset
HS 850 won't go into pairing mode
Feb 29, 2008 | Motorola Mobility HS850 Consumer Headset
Motorola H350 User Manual
On your bluetooth headset, hold down the power button until the light stays on steady. (it will blink when you initially power it on, but continue to hold for another few seconds for the steady light!) Your headset is now in pairing mode.
On your RAZR, press Menu > Settings and Tools > Connections > Bluetooth > Handsfree > Look for devices. Your phone will then scan for any bluetooth devices that are in pairing mode. When your headset pops up on the list, highlight it and press ok to connect.
If the device asks permission to bond with the phone, select yes. It will then prompt you for a pin code. The pin will be 0000 .
Jan 08, 2008 | Motorola Mobility Bluetooth Hands Free...
131 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
