Tip & How-To about Video Game Consoles & Games
XBOX 360 Screen Resolution Reset
Due to the fact I change the TV I use my XBOX 360 on sometimes, I find I connect the console and its output is set higher or to an incompatable resolution that my TV can display. If this has happend to you you need to reset the resolution to default, here's how you do it without needing to see the dashboard:
  1. Remove any discs from the disc tray.
  2. Turn the console off.
  3. Using the player 1 controller turn the console on using the big X guide button.
  4. As the console starts, press and hold the Y button and pull the right trigger at the same time. This causes the Xbox Dashboard to reset the display settings to the default settings and then automatically restarts the console.
Job done!
Video Game Consoles & Games Logo
turn xbox 360 on and no picture on tv, xbox lights up green but doesnt send video output. tv is hd and i have tryed hooking the xbox up to another tv, tryed using hd and regular video outputs, tryed new video output cord, nothing seems to work i think its an internal problem on the xbox
You may need to change your HD settings on the back of the console ( HD setting is actually on cord ) I had that issue when I first went online w/360 . If that does not help u know X box costumer support will repair any damaged system prob. no cost and does'nt take as long as they say.
May 10, 2010 | Microsoft Xbox 360 Console
I was having trouble with my component AV cable. I went to purchase a new cable, HDAV component cable and connected the xbox. I had an image for a short time and now do not. Please help!
your HD settings may be too high, go to "display settings and change them, if your not on an HD tv, change the output to "TV" on the AV cord where it connects to your xbox, if you Are on an HD tv make sure the output is set to "HDTV" on the AV cord where it connects to your xbox, there is a little switch on the side that slides left to right
Jan 16, 2010 | Microsoft Xbox 360 Elite Console
Xbox 360-no audio output
You may need to go into your TV settings and turn on HDMI Audio. If this is not enabled (Typically on HDMI 1) The TV will not ask the 360 for Audio and as such won't pull it.
Jun 20, 2009 | Microsoft Xbox 360 Console
Xbox 360 Elite connected to Mitsubishi HDTV Model No. WD62528
Hudeez: 1. Did you check your TV Menu Settings ?? 2. Also on the XBOX 360 Menu. Go to the SYSTEM MENU (PURPLE). CONSOLE SETTINGS and select DISPLAY. Then you'll find the HDTV Settings and pick your resolution for TV Set. Done....
Jun 05, 2007 | Microsoft Xbox 360 Console
453 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
