Tip & How-To about Computers & Internet
Linksys Router Issue.
1) I have a Linksys router in my home and was having connection problems. After a little research I have found out some things that you can do to make the best connection possible. First use a program called Network Stumbler and scan the wireless networks within your reception area, note what channel your network is on as well as surrounding networks. Write down what channels are being used. Also note the SSID names.
2) Next log into your router's administration account and navigate to the wireless settings. If there is another network nearby with the saame SSID as yours (which could have been left as default settings from the factory) then you will need to change the name of your wireless SSID to something else. I had to do this on my network.
3) Click on the advanced settings and change the channel to one that isn't being used by another network nearby. Example if your network is on channel 4, and so is your neighbor's, then I would change it to channel 6 to put a little space between networks. You have between 1 to channel 11 to pick from.
Step
4) If you have done the above things and are still having connection problems, network interference can be caused by cordless phones, microwave ovens and any electronic that work around the 2.4 Gz range.
Computers & Internet Logo
low connection to Internet
You can change channels, you can't increase frequency. The Linksys WRT54g is a 2.4ghz Frequency wireless device. You can purchase a 2.4-5.0ghz Frequency Dual-Band device. If you have Devices with Wireless N Adapters you will benefit, theoretically, from a N wireless access point increasing speed. Do a little research, there's more to it than replacing a Wireless device. That's only one piece of the puzzle.
Apr 02, 2013 | Linksys WRT54G2 Wireless Router
slow internet for my hardwired computer
its because ur belkin routers MTU is not properly configured in the products ... u need to lower doen the MTu speed ..
Sep 25, 2009 | Computers & Internet
Hooking up wireless linksys
From ethernet of embarq plug it to the Internet port of Linksys. Your PC should be connected to port 1 of Linksys
Aug 17, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G (WRT54GS (EU/LA/UK))
I have had that issue quite often and found that when you are using a router with DSL, the DSL modem and Router IP has a conflict because they are the same number. I suggest looking into a D-Link wireless router for use with DSL.
Mar 17, 2008 | Linksys Wireless-G WRT54GS Router...
193 people viewed this tip
David Payne
David Payne
