Tip & How-To about Office Equipment & Supplies
How to change toner in laserjet printers
First Turn the printer's power off. Some power button is located on the control panel on the top of the printer, on the right side. Open the printer's top cover by pressing the top cover lever, which is located on the bottom side of the top cover. Lift the cover all of the way open. Locate the toner cartridge. It will be right in the center of the printer and has a handle on the top of it. Grab the handle and pull the cartridge out. Hold the replacement cartridge at its side and gently rock it back and forth. This will help to distribute the toner equally throughout the cartridge.Remove the paper cover from the top of the cartridge.Insert the replacement cartridge into the printer and close the printer's top cover.
how to unlock scanner
Turn off the printer and open up the top lid. Turn on the printer and see if the scanner module moved from left to right during start up. There's normally a locking latch for shipping located underneath the control panel in the area where the paper comes out. It would be right above where the paper would sit on the front left side.
Jan 15, 2016 | Samsung Xpress M2070FW Multifunction...
what is the cause of a 51.2M error on a HPLJ4600 color printer
Hello
According to HP following is the remedy for this error
  1. Turn the printer off, and turn it on again.
  2. Remove the surge protector or Uninterruptible Power Supply (UPS) and connect the printer directly to a power source.
  3. Try a different power cord.
  4. Try a different electrical circuit or outlet.
  5. Inspect the fuser for media or damage, and reseat the fuser.
    1. Open the top cover.
    2. Locate the green square tab on the right of the fuser flap and lift it to inspect the fuser roller for media or damage.
    3. Unscrew two blue knobs located on each side above the control panel.
    4. Lift the fuser by grasping the fuser housing above the green arrow on the left and right.
    5. Reinstall the fuser.
  6. Perform a cold reset on the printer.
    1. Turn on the printer.
    2. Watch the control panel.
    3. When the memory starts counting, press and hold the green c00224695.jpg (Select) button.
    4. Continue holding the green check button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    5. Release the check button when the Ready, Data, and Attention light are on steady.
    6. The control panel will display SELECT LANGUAGE .
    7. Press c00224697.jpg (Down Arrow) button once. The control panel will display COLD RESET .
    8. Press c00224695.jpg (Select). The printer will perform a cold reset and then continue its power-on sequence.
  7. If this message persists, contact an HP-authorized service or support provider. Hope it helps, if so do rate the solution
Dec 24, 2010 | HP LaserJet 4600 Printer
how do i insert cadrige
Turn the orinter off and follow these steps:
1) Remove the top cover by opening the top of the printer
2) Pull the older tone cartrige out, taking care of noticing how it is inserted into the printer.
3) Insert the NEW cartridge
4) Close the printer cover
Mar 31, 2010 | Samsung ML 2010 Laser Printer
I just replaced the fuser kit with a brand new NON-refurbished fuser, and it is continually giving me the 50.4 error message and telling me to restart the power and recycle the power. What now?
Hi
Thanks for using FixYa. Error 50.4 means A faulty fuser error has occurred. There may be a problem with the printer's fuser, or inadequate external or internal power supply/line voltage.
a. Open the top cover.
b. Locate the green square tab on the right of the fuser flap and lift it to inspect the fuser roller for media or damage.
c. Unscrew two blue knobs located on each side above the control panel.
d. Lift the fuser by grasping the fuser housing above the green arrow on the left and right.
e. Reinstall the fuser.
a. Turn on the printer.
b. Watch the control panel.
c. When the memory starts counting, press and hold the green (Select) button.
d. Continue holding the green check button until the Ready, Data, and Attention lights flash once, and then stay on steady.
e. Release the check button when the Ready, Data, and Attention light are on steady.
f. The control panel will display SELECT LANGUAGE .
g. Press (Down Arrow) button once. The control panel will display COLD RESET .
h. Press (Select). The printer will perform a cold reset and then continue its power-on sequence.
Please see this link for more detailed info--
HP Color LaserJet 4600dn Printer error 50.4 Details
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 20, 2009 | HP LaserJet 4600dn Color Printer
171 people viewed this tip
jasbo
jasbo
