Tip & How-To about RCA OPAL M4001 MP3 Player
My Opal does not start. How do I reset my Opal?
Hi.
The procedure below is the full troubleshooting when the RCA Opal is completely irresponsive and does not complete initialization.
Try first holding down the Power/Menu button for over ten seconds. This is called soft reset, and will reset the player to default factory settings. This reset will not delete personal files.
Depending on the model you may also have a reset button. In that case hold down the pinhole switch using a paper clip for more than ten seconds to perform an hard reset. It will take one or two minutest to restart the Opal after this reset, as files must be reinstalled.This reset will delete files and personal settings.
If that does not work, it means that system files are damaged. In that case you will need to reinstall the Opal firmware. Firmware for some model may be available online, but better calling or contacting RCA and asking them to provide you with an updated firmware for your unit. If the wrong firmware is installed the Opal may result damaged.
RCA can be contacted at the number listed on Opal documentation. Number in US should be: 1-800-878-5779 (RCA Audio Products Repair Centers and Warranty Info).
You can also get the firmware asking a question online. Use the following link: Create an Incident or ask a question.
See also: Information on RCA Opal M4001 MP3 Player.
To update firmware follow procedure below:
Download the firmware upgrade file.
Hold down the play/pause button for about twenty seconds .
Hold down menu button for more than 10 seconds
Keep holding play/pause button and attach Opal USB cable to computer at the same time.
The firmware upgrade will start
If you get an error saying that Windows cannot write to the Opal drive, that means that the Opal internal drive must be re-formatted. In that case go to Computer, click the right button of mouse on the Opal, and choose Format from the dropdown menu.
After formatting, restart both units, and restart firmware upgrade procedure.
Note: The procedure above must be used when the Opal is not starting at all. When instead the opal is starting, but it is not recognised by the computer, procedure will be different. In that case test the player on a different computer. Test different USB cable.Restart computer and Opal. Reset computer by disconnecting power cord, and eventually removing battery for five minutes. Try using System Restore to restore the computer to a date before having the problem. Reinstall Windows Media Player. Check System and USB hardware settings and driver on computer..
RCA OPAL M4001 MP3 Player Logo
wont do nothing but initializing
Hi.
The procedure below is the full troubleshooting when the RCA Opal is completely irresponsive and not completing initialization.
Regards.
Mar 31, 2010 | RCA OPAL M4001 MP3 Player
how do i put videos on my opal mp3
Log onto the RCA website and download the RCA SMV Video Converter. The Opal only plays videos that are in one specific format. This converter will put your videos into that exact format (see Resources below).
  • Install the RCA SMV Video Converter once you have downloaded the software.
  • Open the RCA SMV Video Converter software to begin putting videos onto your RCA Opal.
  • Connect the RCA Opal to your computer using the USB chord that came with the device.
  • Wait until the RCA SMV Video Converter software reads that the device has been connected. You will know this when the bottom of the software screen reads “Player Detected: Opal 1GB 2GB.”
  • Select the “Browse” option to find any videos that are on your computer which you wish to add to the RCA Opal.
  • Click the box next to “Transfer output files to OPAL 1GB 2GB after conversion is complete” after you have selected all of the videos which you wish to convert. This will automatically add the videos to your RCA Opal after they have been converted.
  • Click the “Convert” box after you have selected all of the videos. The videos will automatically begin to convert to the correct format. Once they have been converted, your videos will automatically upload to your RCA Opal.
  • Oct 04, 2009 | RCA OPAL M4001 MP3 Player
    how to i play videos on a RCA M4204
    Oct 03, 2009 | RCA M4204 MP3 Player
    freezing up on initializing; wont charge; computer not reconizing it
    Hi There
    You Can Download Free MP3 From Youtube By This Site : video2mp3.net
    If you didn't found Your Favorite Music In Youtube Try These Sites : Beemp3.com or 4shared.com
    May 20, 2009 | RCA opal MP3 Player
    my rca opal mp3 player freezes on the screen where it says initializing when i turn it on?
    Go to "http://voxrightnow.custhelp.com/cgi-bin/voxrightnow.cfg/php/enduser/std_adp.php?p_faqid=2559"
    To update the firmware of the M42xx mp3 player click here and download the firmware. start the firmware and when it is runnin plug the M42xx in at the same time holding down the PLAY BUTTON (center) until a white screen with a small computer with a line going to your M42xx is displayed and then release the PLAY button. You can then click on start and the firmware update will complete,,, DO NOT DISCONNECT DURING THIS UPDATE... it may take 2 times to complete this but it will work.... YEA!!!!
    CARL
    Nov 07, 2008 | RCA M4204 MP3 Player
    1,570 people viewed this tip
    Top RCA Audio Players & Recorders Experts
    Gyula Lacz
    Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
