Tip & How-To about Computers & Internet
Vmware enable SSH
If you want to do advanced features in VMware ESXi you will need to go into the core of ESXi to do this you can use Secure Shell or SSH. SSH is simplar to telnet but the data is encypted.
To enable SSH on VMware ESXi you need to enter an the ‘unsupported’ mode.
Step 1. At the physical console of the ESXi server press the Alt+F1 key combination.
Step 2. Type ‘unsupported’ and then press . Note that nothing will appear on the screen whilst you type.
Step 3. When prompted enter in the ‘Root’ password and press .
Step 4. You will now be presented with a prompt on the console. From this prompt type the following command
vi /etc/inetd.conf
Step 5. vi (the file editor) has now opened the inetd.conf file. Using the direction arrows scroll through the lines until you reach the line that has ‘#ssh’ and remove the hash (ie: #). This is effectively un-commenting this line so that the ssh service can be started.
Step 6. Now that you have made this minor file you want to save this change and exit out of the editor (vi). To do this press the ESC key (to put vi back into Command Mode) and then type ‘:wq’ *Note: If you want to exit without saving any changes to the file then just press the ESC key (Command Mode) and then type ‘:q!’.
Step 7. With the SSH service now un-commented from this file we need to restart out ESXi box to do this type in Reboot.
Computers & Internet Logo
X8DTL-3F ESXI RAID
ESXi is definitely supported on Supermicro's X8DTL motherboard. However, software RAID is not supported.
If you are having issues with a specific hardware RAID card, check the compatibility list for your card.
VMware Compatibility Guide
Jul 02, 2012 | SuperMicro X8DTL-3F Server Board -...
64 bit os vmware esxi
make sure that the Ubuntu is seeing an X386 and not a X686 emulated processor. Ubuntu stopped support on 686 procs for the 64bit family awhile back. you can choose this under the items.
Apr 20, 2010 | HP Compaq ProLiant DL360 G4 Server
VMWare Clustering with Veeam or just replication
There are several advantages of clustering, as you stated, ease of server environment replication is one of these advantages. There are several others, instant fail-over replacement, swaping from one machine to the other for hardware / software maintentance / upgrades with little to no downtime during the proceedures, shared access to similar content / configurations, there are many many reasons to cluster.
you may also look into ESXi:
VMware ESXi is the easiest way to get started withvirtualization—and it’s free. Consolidate your applications onto fewerservers and start saving money through reduced hardware, power, coolingand administration costs. VMware ESXi has been optimized and tested torun even your most resource intensive applications and databases withminimal performance overhead. With VMware ESXi you can:
You can download ESXi from -=[ HERE ]=-
Nov 03, 2009 | VMware ESX Server (370598B21)
looking for virtual network adapter for installing Vshpere on a VM workstation
Vmware product for server like ESX and ESXi accept mostly Broadcom cards and intel cards preferably the server ones.
I have successfully installed esxi 3.5 on Intel 10/100S cards myself.
Here is a list of compatible Hardware: list
Jun 19, 2009 | 3Com Computers & Internet
VMware
Since you do not have a DVD, Vista is out, That leaves you with Windows XP (if you have it) or Linux/BSD. Your question does not give a lot of details, are you trying to install VMware Server or ESXi?
Both are free but there is a big difference, ESXi is a bare metal hypervisor and VMware Server is not. This means the ESXi does not need an operating system already installed but VMware Server does.
VMware has posted hardware that is compatible with ESXi but you should note that you really need at least 2 computer to run ESXi - one as the actual server and another to manage it. With VMware server you only need one machine and it is less sensitive to hardware but you have to have an operating system already installed on the machine, then load the VMware server and then create the virtual machine. What type of machine are you trying to create VMware supports practicaly all versiona of windows and linux. Can you detail what you have and what you have done so far to get the error message?
Sep 27, 2008 | VMware VirtualCenter for PC
975 people viewed this tip
David Payne
David Payne
