Tip & How-To about Televison & Video
I see multiple coloured images on my projection TV
If the error is severe, this is a convergence problem. Convergence ICs are not too hard to change but require good soldering skills. There can be two or three ICs. There may be a blown solder-in fuse or two.
A service shop will charge $200 -$600 depending on service call, parts costs, labour, etc.
A slight error in one or two colours that just barely won't correct is an alignment issue. There are a lot of internal adjustments done by remote. Digital adjustments are not forgiving. Have a pro do the adjustment.
Televison & Video Logo
i have a 60 inch rca rear projection tv and it looks like the screen is bowed can i fix this myself or will i have to pay someone to do it
Ur tv have a problems known as a convergence picture problems it is dead.The tv convergence board it is dead and must have to repair like replacing 2 STK convegence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.Yes,u can fix it and do the works by ur self.But u have to have all the requirement tools,have the skills and the know how to do the work on a circuit board and can do basic soldering work like take out ICS chips and replaces ICS chips on a soldering circuit board and also can take out some small dead components parts and replaces it with doing a soldering works.U can do that?Yes?Tries websites like Tvrpairworld.com,Tvrepairkits.com to buy a whole complete convergence kit that belong to ur DLP tv make and mode about $70-$75 also the kit will have a DVD tutoring disc.As i said u have all tools and the skills to work on a cucuit board and changes ICS and resistors u can do the job ur self.Or tvs shops will cost u like $300-350 for parts and labors.
Aug 30, 2011 | Sony KP-51WS500 51" Rear Projection...
We cannot align the blue. The projectors appear
If the error is severe, this is a convergence problem. Convergence ICs are not too hard to change but require good soldering skills. There can be two or three ICS.
A slight error that just barely won't correct is an alignment issue. There are a lot of adjustments done by remote. Digital adjustments are not forgiving. Have a pro do the adjustment.
Mar 31, 2010 | Hitachi 53FDX01B 53" Rear Projection...
three colors bleed on screen and shadows reduces to portion of top screen model mitsubishi 60'' 2001 how to fix
** Caution! Hazardous voltages inside. Technical experience required.
This is a convergence problem. You will need repairs done. likely will cost $200-$600 depending on parts, service call, labour, etc. The convergence ICs are not particularly hard to change but you need good solder skills.
Mar 30, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Can't correct my red blue convergence manually or by using factory preset...the unit is 7 years old, is my picture tube bad?
You have bad convergence ICs. There are 2 ICs in the convergence circuit, one is for the Blue the other is for the Red. You can buy 2 ICs for under $40.00. Replacing these ICs require soldering and desoldering skills. Sometime, the resistors in the convergence circuit go bad also. Be very careful, there is a very high voltage in a CRT projection TV the voltage is over 30,000 volts.
Best of Luck
Sabre
Feb 23, 2010 | Philips 60PP9202 60" Rear Projection...
144 people viewed this tip
Top Televison & Video Experts
