Tip & How-To about Cameras
My camera has spots in the picture
The spots are caused by the flash being SO close to the lens. Anyobject that can reflect the flash reflects it right back at the camera.
This is an image problem with most point and shoot digitals. Watch forreflective surfaces and stand at an angle to them. Turn on more lightsin the room before using flash. Most indoor pictures start way too dark.
Stand at a slight angle to the image orperson you are photographing - don't shoot straight on. (I kneel downand shoot up - makes a good shot too.)
If you are shooting toward the sun lit side of an image, shield the lens from direct sunlight with your hand (Keep your hand out of the picture!)
A professional photographer has the flash way away from the lens for a reason...
Cameras Logo
when capturing picture in open-air at time of night.... my dmc f3 cam shows spots in picture spots if dust particles present in the air which spoil the look of picture :( plz help
If these are flash pictures, you are experiencing dust particles in the air reflecting the flash back into the camera lens. This is a problem with point and shoot cameras because the flash is so close to the lens.
Mar 13, 2011 | Panasonic Lumix DMC F3 Digital Camera
Hello Sir or Madam, My wife has recently taken pictures and most of her pictures have white spots in them, does this mean that my digital camera is defective?
Do the spots only occur when taking flash pictures and do the spots look like "soap bubbles" and appear in different places in each picture? If so, these are dust particles reflecting the flash back into the lens. It's a problem with all point and shoot cameras because the flash is so close to the lens.
Nov 01, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
there are some spots on a picture that look grey(shadowing)? what is the cause of this
Do these spots look like soap bubbles and do they appear at different places on each picture? Also, do they only appear when you take flash pictures? If so, these are dust particles reflecting the light back into the lens because the flash is so close to the lens. We all have this problem.
Oct 25, 2010 | Pentax Optio 30 Digital Camera
I have a Sony DSC T-90 12.1 megapixel. I often
The vertical line can be caused by a very bright object in the image like a lamp or a silver surface reflecting the flash.
The spots are caused by the flash being SO close to the lens. Any object that can reflect the flash reflects it right back at the camera. This is an image problem with most point and shoot digitals. Watch for reflective surfaces and stand at an angle to them. Turn on more lights in the room before using flash. Stand at a slight angle to the image or person you are photographing - don't shoot straight on. (I kneel down and shoot up - makes a good shot too.)
If you are shooting toward the sun, shield the lens from direct sunlight with your hand (Keep your hand out of the picture!)
Mar 31, 2010 | Sony Cybershot DSC-T77 Digital Camera
Spots on image when using built-in Speedlight flash
As is common in many compact digital cameras where the built-in flash is very close to the lens strange reflections can appear in images under certain conditions. Particulate matter in the air in front of the lens (between the camera and subject) such as water vapor (as in a cloudy day), smoke, dust or other items can reflect light directly into the lens causing neutral colored white/grey semi-transparent spots to appear in the image. In extreme examples there may be many of these spots in an image or there may be only one per image. Also, since these spots are completely random they will move or disappear from image to image. For example, if two images are shot consecutively with the same camera settings one image may have spots while the other is clean. To avoid these spots: When possible, avoid photographing in smoky, dust, or cloudy areas Do not use the camera's flash in locations such as above Use an external Speedlight flash if a flash is needed Review images on the camera and re-shoot if spots are visible Cleaning the lens will not have an effect on these spots, as the particles that cause this are not on the lens itself.
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
293 people viewed this tip
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
