Tip & How-To about Dryers
Your dryer runs but there's no heat? Check this money-saving tip!
It happens...And usually when you have many loads of laundry to do because you're leaving on holiday this weekend...The dryer tumbles, but won't heat! Have no fear, because the fix could be simpler than you think!The first thing you may want to check is the thermal fuse (or sometimes called a "cutout.") It is VERY common for these to blow due to age, but another thing, while you have it apart, it will be a good opportunity for you to use a shop vac to clean out all of the lint that gets packed in there, in all those places behind the back panel. :) To access the thermal fuse on most models, UNPLUG THE DRYER, shut the gas off (for added safety) and remove the back panel. They (the thermal fuses, or cutoffs) commonly look like one of these:
Again, with the dryer unplugged, disconnect the two wires going to the fuse. Next, with a volt-ohm meter set on OHMS or CONTINUITY, check to see if the fuse shows little or no resistance. If not, (which it probably won't) replace the fuse. It is VERY easy to replace and best of all, most appliance parts stores sell them. You can also order them online. Open the dryer door for the actual model and serial number and you should be able to find a replacement with little effort.
I hope this helps! And if you are, in fact leaving somewhere this weekend, at least you might be able to go now with clean and DRY clothes! :)
Dryers Logo
e15 error code on hoover tumble dryer
Controls
  • The control unit on the tumble dryer will vary among different makes and models. The main purpose of the controls is to allow the user to select the drying cycle. You can choose the time and temperature setting on most units, while others allow custom settings such as moisture sensors and end-of-cycle alert signals. The controls may include a dial or a touch panel and LED screen display. Some tumble dryers allow you to independently select the appropriate time for the load you are drying and separate programs for temperature.
Motor
  • The motor inside the tumble dryer spins the basket to allow the clothes to tumble while being dried. The tumbling action allows the air to pass through the clothing to dry them faster. Heating laundry that is stagnant will likely dry the clothing on the outside while leaving damp clothing inside the pile. The constant motion, along with the heat and steam created by heating the clothing, reduces wrinkles. The motor also powers the fan that delivers the heated air to the basket of laundry. The heater can be an electrical element or gas powered.
Jan 15, 2013 | Dryers
lhe5700wo won't heat after power outage
the heating element may have burnt out , you can purchase on for around $25 dollars , also check thermostats, I usually find where the heating element has burned into, then spice it back together with a stainless steel electrical **** connector , check with ohm meter . heating element runs in a metal box shaped container and looks like a spring coiling through ceramic insulators .
Mar 13, 2012 | Dryers
my gas dryer won't tumble or heat
sounds like a few things are wrong/ needs checked, will not tumble is usually the belt, no heat is usually a thermal fuse if the pilot light is lit. Here is a website that will assist you Tim:
http://www.applianceaid.com/gas_dryer.html#noheat
May 15, 2011 | Kenmore Dryers
Kenmore 600 dryer tumbling & heating, but not drying
Several reasonings. Step One make certain that you have 220 volts coming to your outlet. It takes 110 for the motor, and it takes 110 for the heating elements. If you have a volt meter that would be the best way to do that. Take the red and stick it in to the long part, and the black lead to the ground. Fuse houses was bad about this. Step Two it could be the elements are kicking off too soon. That is usually a sign of almost blown element. Step Three the heat sensor for the element prematurely kicking off the element.
Aug 10, 2009 | Kenmore 600 7965 Dryer
Dryer not taking out moisture
your venting from the dryer probably also submerged in the "flood", try taking that apart and make sure its not clogged, sounds as if the dryer is not able to release the heat that its producing
Jul 25, 2008 | Dryers
163 people viewed this tip
Top Dryers Experts
