Tip & How-To about Refrigerators
How do I change freezer door opening side?
Hi.
Details on how to change the fridge door opening side depend on the appliance model.If this is a chest unit, you will simply need to rotate the unit. On most upright units the general procedure to change door opening orientation is more or less the one ilustrated below:
  1. Disconnect power from the appliance.
  2. Get to the top side of the unit, and remove the hinge plate. This is usually held by two Torx or Philips screws. You may need to help yourself with a putty knife to remove a protective panel covering the plate. Be careful not to damage any part.
  3. Remove top hinge and put it on one side.
  4. After removing the plate you may need to remove the plastic clip located at the top on the handle side of the door, oppositely to the old hinge side. Use the putty knife to pry up and remove the plastic clip.
  5. Open the door and lift it from the lower hinge pivot.On many fridges you will have to remove the bottom hinge too, often held by two screws, and covered with a proective pane, to free the door before removing it
  6. Carefully place the door on the floor.
  7. Remove protective panels on top and bottom on handle side of the frige cavity, reinstall the hinges on handle side position, swapping them with the protective panels.
  8. Remove the door pivot and mount it on the opposite side.
  9. On the door disassemble and refit handle or any other part if needed.
The precise and complete procedure is usually illustrated on the appliance user manual. If you need manual or schematics, try asking a new Fixya question. Ensure that you are providing full model number, as printed on service tag.
To get more detailed info you can also try calling the appliance manufacturer at the number listed on the owners manual.
Regards.
Refrigerators Logo
how do I level my domestic kelvinator fridge . the floor seems to be level . I recently relocated to Cairns
the front feet under the door opening are adjustable screws. You may have to use a shifter to get them to move as they mat be rusted . adjust so the fridge slopes slightly to the rear. This keeps any moisture on the back wall to drain out the hole and the door will close if left open
Mar 03, 2015 | Kelvinator 12 cu. ft. / 340 liter Chest...
What is the temperature suppose to be inside fridge?
fridge is supposed to be around 36-38 degrees freezer 0 to 10 depending on if your fridge area is not cold enough the freezer is the only side that actually gets cold and there is a fan located above the evaporator that pushes to cold air through a small door that opens and closes depending on how cold your unit is. If the unit gets to cold the door shuts not allowing any cold air to come into the fridgerator side. If you have any further questions message me back. Please also remember to rank how this opinion has helped in your appliance situation when our chat has fully completed it allows me to continue helping others in similar situations in the future Thanks Rick
Jun 11, 2011 | Whirlpool Refrigerators
fridge not working but freezer is ok fridge light works
There is probably an ice build up between the two sides of the appliance. There may also be a problem with the damper unit which controls the cold air coming from the freezer side to the fridge. The fridge is controlled by the freezer. Dependant on appliance. The door opens and closes letting the cold air go into the fridge and when the fridge is cold enough the door will close agin. This is not something that you will see happening it is normally concealed behing a diffuser.
Feb 24, 2010 | Freezers
FREEZER SIDE TOO MUCH ICE FRIDGE SIDE NOT TOO COLD
If it has ice buildup on the back wall inside the freezer, it appears to have a defrost problem. Unplug it, put your food in another unit (or ice chests), open the freezer door and let it thaw out overnight for at least 12 hours or more, or until all the ice has melted from *behind* the back wall. Then close the doors and run it for 4 hours and check to see if the fresh food side is cold. If it is, call a repairman to fix the defrost problem. That could be a burned out heater, terminator, or defrost timer depending on your exact model.
Jan 03, 2010 | Whirlpool Refrigerators
449 people viewed this tip
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
