Tip & How-To about Computers & Internet
How to Hack Into a Windows XP Computer Without Changing Password
Login to a password protected Windows even if you do not have the password is by making Windows accepting any passwords.
There is a far better way to get into Windows XP. It is easy and it does not reset the password. Hack into a computerrunning Windows XP without changing the password and find out all andany passwords on the machine (including admin accounts). You do notneed access to any accounts to do this. Of course, do not do this onanyone elses computer without proper authorisation.
Steps to Hack into a Windows XP Computer without changing password:
1. Get physical access to the machine. Remember that it must have a CD or DVD drive.
2. Download DreamPackPL HERE.
3. Unzip the downloaded dpl.zip and you’ll get dpl.ISO.
4. Use any burning program that can burn ISO images.
5. After you have the disk, boot from the CD or DVD drive. You will see Windows 2000 Setup and it will load some files.
6. Press “R” to install DreamPackPL.
7. Press “C” to install DreamPackPL by using the recovery console.
8. Select the Windows installation that is currently on the computer (Normally is “1′ if you only have one Windows installed)
9. Backup your original sfcfiles.dll by typing:
ren C:WindowsSystem32sfcfiles.dll sfcfiles.lld” (without quotes)
10. Copy the hacked file from CD to system32 folder. Type:
copy D:i386pinball.ex_ C:WindowsSystem32sfcfiles.dll” (without quotes and assuming your CD drive is D:)
11. Type “exit”, take out disk and reboot.
12. In the password field, type “dreamon” (without quotes) and DreamPack menu will appear.
13. Click the top graphic on the DreamPack menu and you will get a menu popup.
14. Go to commands and enable the options and enable the god command.
15. Type “god” in the password field to get in Windows.You can also go to Passwords and select “Logon with wrong password and hash”. This option allows you to login with ANY password.
Note: I was unable to bring up the DreamPackPL forthe first time because I have Kaspersky Anti-Virus already running inbackground. I believe most antivirus already labelled this tool as aHack-Tool. A Hack-Tool is NOT a virus. DreamPackPL helps you bypass theWindows Login screen and it is not destructive.
{please rate my article{
Computers & Internet Logo
Cannot log onto my Dell Inspiron 1525, password not recognised.
That is right. Not only you need a password, to open the PC and be able to run the programm's, the password is also a key for encription of the data. No password, no data.
When you do a reset, and install Windows again, you will lose all data on the computer. So is you really can't remember the password and you did not make a mistake with the caps, you should be lost.
I know there are some less legal program's around, but I can't tell you what programs and I even don't know a name. I think you better use Google, to find out which program's are available and how to get them. Perhaps via news groups. But be aware program's to hack a password, come from a certain community. When you have a program, didconnect the computer from the net, try to recover the password and backup the data unscrambled. Then run a good virus scanner and delete the program.
Just saying.
Apr 22, 2015 | Dell Inspiron 1525 Laptop
remove password password
Reset Administrator Password ' Free and Fast Methods to Reset Administrator Password
Are you looking for ways to reset administrator password? Do you believe there are several free and also fast methods to administrator password reset? Windows Password Recovery Tool can release all your doubts!
Feb 17, 2011 | Sylvania G-Netbook
cant get in to my computer lost my password
If you can tell me what the Os do you use, it could be must better.
On XP you can try this:
Boot computer and press Ctrl+Alt+Delete twice when you See Windows welcome screen / login screen. It'll show classic login box. Now type "Administrator" (without quotes) in username field and leave password field blank, press Enter and you should be able to login Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
On Win 7 or Vista:
Ctrl+Alt+Delete won't work, you have to use some windows password reset tool. I recommend Windows Password Reset.
Resource: http://www.windowspasswordreset.net
Nov 05, 2009 | Acer Windows Vista TL-562G Notebook
245 people viewed this tip
David Payne
David Payne
