Tip & How-To about Computers & Internet
How to change the virtual memory of your computer.
Memory (RAM) is the most important part of a system. The more the memory the stronger the system.
You can buy a physical memory(RAM) and install it, which faster and more reliable but a bit expensive.
But wait you can increase your memory by allocating a size of the Hard disk which is absolutely free but not as fast as RAM.
I must tell you that Virtual Memory can't be compared to Physical Memory. Physical Memory is way faster and most reliable.
But still whats bad in allotting it for free.
To increase your memory in XP you just follow my easy 1-2-3 recipe:
1. Open My Computer
2. Right Click and select properties.
3. A new window appears click on the tab named "Advanced"
4. Click the first button named "Settings"
5. A new window appears now select the tab named "Advanced"
6. Click the button named "Change" at almost the bottom of the window
7. Click the Radio Button Named "Custom Size:"
8. Depending on your Hard disk write the amount but let me tell you the recommended amount Initial 753 and Maximum 1506.
9. Click all the Oks
10. You're done now re-boot your system.
Please try this at your own risk although I have tested this and many others as well, I have never encountered any problem, but some people cross the limits make the virtual look like a Hard disk which is not possible and can be harmful
Computers & Internet Logo
Alienware m17x physical memory
Does it have multiple sticks of RAM or just one?
Does it show 4GB in the BIOS?
Have you tried CPUZ to see what it says your physical RAM size is?
Is your system RAM shared with the onboard video?
Nov 04, 2013 | Alienware PC Systems Computers & Internet
Installed physical memory 4 GB but total physical memory 2.67GB
You need to be using a 64-bit operating system to address all 4GB of RAM.
Sep 02, 2012 | Samsung Ram Memory 4gb Ddr3 Pc3...
Acer Aspire E500 RAM
This is because your computer is sharing the physical memory with the graphics memory so it will actually subtract the amount of the shared memory from the physical memory in the computer giving you the 780 that you see because the computer reserves a portion of that to use for your graphics.
Jul 06, 2009 | Acer Computers & Internet
memory confusion different readings
It sounds like something isnt working right, what operating system are you using, Vista? I would take out the original 512 and see what it says after, often ram isnt compatible if it is too different in size and speeds. Also, if your motherboard supports dual channel ram and you have the extra 512 chip it wont run in dual channel mode, you would run better with just the 2 chips then the added 512 chip.
Jan 17, 2009 | Mach Speed (S755) Motherboard
ram problem
IT IS A SHARED MEMORY
You won't like the resolution if you remove the 8mb buffer in bios set-up, trust me.(it will make your display look like 16color windows 3.1 or worse) You could try it and it will get you back that 8 meg the other is shadow ram, don't mess with that either.
Your options in advanced video are 8mb and 1mb. My advice, leave it.
Apr 19, 2008 | E-Machines eMachines Desktop PC
524 people viewed this tip
David Payne
David Payne
