Tip & How-To about Computers & Internet
IP address 0.0.0.0
First of all, disable and re-enable the connection. When you change the IP address from automatic to a fixed IP address while the adapter is not connected, you always get a 0.0.0.0 address at first when the adapter reconnects. If this doesn't solve the problem, read on.
Symptoms:
  • You cannot obtain an IP address from the DHCP server. The IP address is 0.0.0.0.
  • The DHCP service is not running, although it is set to Start Automatic.
  • When you try to start the DHCP service, you get the error message: Could not start the DHCP Client Service on Local Computer. Error 1075: The dependency service does not exist or has been marked for deletion.
This problem can occur after uninstalling Norton AntiVirus, which sets the DHCP service as depending on itself. It can also occur when the computer name of the client computer is too long. Make sure that all computer names in your network are no longer than 15 characters.
First set a restore point, so you can undo your changes, should anything go wrong (Programs, Accessories, System programs, System restore).
After setting the restore point, to remove this dependency, do this:
  • Click: Start
  • Click: Run...
  • Type: regedit
  • Click: OK
  • Navigate to the following keys in the registry:
    HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\DHCP
    HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\NetBT
  • For each of these, on the right side, double-click: DependOnService
  • Delete any lines containing either SYMTDI or NISDRV.
  • Click: OK
  • Close the Registry Editor.
  • Reboot.
Computers & Internet Logo
cant connect to my wireless router and the 192.168.01 url entered doesnt help none
Windows XP
  1. Verify Ethernet adapter in device manger.
    1. Click Start > Search > Type in ncpa.cpl and press Enter.
    2. Click System>Hardware > Device Manager
    3. Click Network Adapters
    4. Verify adapter present, enabled, and no error messages.
    5. If error reported refer to OEM regarding error receiving
  2. Open the Network Connections window.
    1. Click on Start > Run > Type in ncpa.cpl and click OK.
  3. Double-click on the Local Area Connection icon.
  4. Click the Support tab.
    1. Ensure that Address Type: says "Assigned by DHCP."
    2. Ensure that the IP address is valid.
    3. If both are correct, click the Repair button and then skip to Step 9.
  5. If it does not say "Assigned by DHCP" click the General tab and then click Properties.
  6. Select "Internet Protocol TCP/IP" and then click on the Properties button.
  7. Ensure that the radio buttons are marked as "Obtain an IP Address automatically" and "Obtain a DNS Server address automatically" and click OK.
  8. Click OK again to close out of the Local Area Connection properties.
    1. Restart the system if any changes were made to the configurations.
  9. Right-click on Local Area Connection and select Repair.
  10. If the repair fails because the system is unable to flush the ARP Cache, the Routing and Remote Access service will need to be stopped and set to disabled.
    1. Click Start>Run>Type services.msc >Click OK.
    2. Double-click on Routing and Remote Access.
    3. Click the Stop button.
    4. Set Startup Type to Disabled and click Apply, then OK.
    5. Restart system.
  11. If the Repair fails to renew the IP address, ensure that all firewalls are disabled and try again.
  12. If it still fails, reset the networking protocols.
    1. Click Start>Run>Type CMD and click OK.
    2. Type netsh int ip reset reset.log and press Enter.
    3. Type netsh int ip delete arpcache and press Enter.
    4. Type netsh winsock reset and press Enter. (SP 2 or later)
    5. Type ipconfig /flushdns and press Enter.
    6. Restart the system.
Windows Vista
    2. Click Hardware and Sound > Device Manager
  2. Open the manage Network Connections window.
  3. Right-click on Local Area Connection and select Properties.
  4. Uncheck Internet Protocol Version 6 (TCP/IPv6).
  5. Select "Internet Protocol Version 4 (TCP/IPv4)" and then click on the Properties button. (Do Not Uncheck Version 4).
  6. Ensure that the radio buttons are marked as "Obtain an IP Address automatically" and "Obtain a DNS Server address automatically" and click OK.
  7. Click OK again to close out of the Local Area Connection properties.
    1. Restart the system if any changes were made to the configurations, including unchecking TCP/IPv6.
  8. Right-click on Local Area Connection and select Diagnose.
  9. If Diagnose fails to renew the IP address, ensure that all firewalls are disabled and try again.
  10. If it fails again, choose to "Reset the Network Adapter."
  11. If it still fails, reset the networking protocols.
    1. Click Start>All Programs>Accessories.
    2. Right-click on Command Prompt and select "Run As Administrator"
    3. Type netsh int ip reset reset.log and press Enter.
    4. Type netsh int ip delete arpcache and press Enter.
    5. Type netsh winsock reset and press Enter.
    6. Type ipconfig /flushdns and press Enter.
    7. Restart the system.
Windows 7
I hope this helps
Oct 01, 2010 | Computers & Internet
My laptop cannot automatically pick up an IP address
Don't send it away.
To automatically get an IP addressed assign you must have the network adapter set to "Obtain an IP address automatically"
Check it from a command prompt
click on start | run| type in cmd to open a command window
type ipconfig /all in the command window and see if Autoconfiguration Enabled . . . . : Yes is in the list of information, if not follow the guide below to change it.
DNS service and DHCP service are not normally run on a person's computer, these are services that run on remote internet servers, local network servers or router/wireless access points, to name a few examples.
You need to verify that your network adapter's TCP/IP settings are set to automatically obtain an IP address.
Go to network connections and open the window.
Find your network adapter and right click once on it and select "PROPERTIES" at the bottom of the context menu list that appears.
Usually this will be labeled something like Local Area Connection.
Right click on it and select properties.
In the window that open you'll see several items with checkboxes, find the one labeled
Internet Protocol (TCP/IP), click once on it to select it and then click on the button "PROPERTIES"
Look and see if the bullet choice "obtain an IP address automatically is bulleted, if not click in the circle to enable the bullet.
While in that properties sheet, make sure that the item Obtain DNS server address automatically is also bulleted (selected)
Click OK, OK
click on START | RUN and type in the box cmd to open a command window
in the black command window type the command
ipconfig /all
you should see an IP address, subnet mask and default gateway along with lots of other IP info
see if you've got an IP address in the list. If not type the following in the command window
ipconfig /release
this will force the IP to release any address it is holding
then type
ipconfig /renew
this will force a renew of the address
C:\Documents and Settings\tolm4454>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : NAME OF COMPUTER
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . :
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Broadcom NetXtreme 57xx Gigabit Cont
roller
Physical Address. . . . . . . . . : 00-19-B9-43-65-C3
Dhcp Enabled. . . . . . . . . . . : Yes
IP Address. . . . . . . . . . . . : 10.53.0.148
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . : 10.53.0.254
DHCP Server . . . . . . . . . . . : 10.53.100.252
DNS Servers . . . . . . . . . . . : 10.53.100.195
10.53.100.136
10.23.100.22
Primary WINS Server . . . . . . . : 10.53.100.253
Secondary WINS Server . . . . . . : 10.53.100.252
Lease Obtained. . . . . . . . . . : Monday, March 16, 2009 12:22:20 PM
Lease Expires . . . . . . . . . . : Thursday, March 19, 2009 12:22:20 PM
Mar 16, 2009 | HP Computers & Internet
Acer 3000 builtin Wireless adapter says disconnected
update the drivers and run the wizard again to set up fresh settings
are you networking this unit or direct of the modem
Feb 11, 2009 | Acer Aspire 3000 Notebook
wireless router
My suggestion would be to first disable any encryption on the router to make your wireless network simple first to try and troubleshoot these problems. check if any MAC or IP Address filters are active on the wireless router, you can either enter the IP address of the slingbox wireless adapter or its MAC address if you HAVE enable filtering, but again, try diagnosing without filtering or encryption enabled. Also ensure your slingbox wireless adapter has its settings set to 'automatically assign IP address (enable DHCP)' so it gets its address automatically.
May 04, 2008 | D-Link Wireless
wireless connection problem
Internet Setup
Internet Connection Type: Obtain an IP automatically
Host Name: linksys
Domain Name:
MTU: Enable Disabled
Speed & Duplex: 10 Mb Half
Local IP Address: 192.168.1.1
Subnet Mask: 255.255.255.0
Local DHCP Server: Enabled
Start IP Address: 192.168.1.
Number of Address: 50
DHCP Address Range: 192.168.1.100 ~ 149
Client Lease Time: 0 (0 means two day)
Static DNS 1:
Static DNS 2:
Static DNS 3:
WINS:
DDNS: Disabled
NAT: Enabled
Dynamic Routing: Disabled
Wireless: Enabled
Wireless Network Name(SSID): linksys
Wireless Channel: 6 - 2.442 GHZ7
Wireless SSID Broadcast: Enabled
Wireless Security: Disabled
Feb 23, 2008 | Dell Inspiron 1200 Notebook
156 people viewed this tip
David Payne
David Payne
